help with Arduino pro Micro
lnejman
PostPosted: Mon Nov 30, 2015 11:27 am    Post subject: help with Arduino pro Micro Reply with quote
I have tryed with all the tip and trix for this arduino that i can find , but no luck Crying or Very sad
This board works fine with Arduino IDE but not with Bascom.
Bascom works with outher Arduino board (UNO rev3).
Have Anyone get Bascom to work with Arduino Pro Micro ?? Question
PostPosted: Mon Nov 30, 2015 4:58 pm    Post subject: Reply with quote
hello,
this Arduino/Genuino is based on a M32U4, with the usb controler and bootloader inside.
Actually Bascom does'nt support it as an ARDUINO
but
Bascom knows the M32U4, this board has an isp port (6pins) so you could use an ISP programmer as the AVRISP MKII
I add a memo (sorry in french but with a lot of pictures,) how to install the AVRISP Programmer (same for studio7)
let me know your progress.
JP
Bon courage
Wink
lnejman
PostPosted: Mon Nov 30, 2015 9:25 pm    Post subject: Is this programmer possible to use Reply with quote
I have purchased a ISP programmer that should be compatible with STK500
Its called Olimex.
Is it possible to use this one?? Question
this is the description:
AVR-ISP500 is a fast and reliable USB AVR programmer, and works directly with AVR Studio. It is recognized as a STK500 programmer and programs all AVRs. It emulates USB CDC so no drivers are required and works under Windows, Linux and MacOS. If you do not want to use AVRStudio you can use AVR-ISP500 with AVRdude.
Features:
Connects to PC via USB 2.0 Full speed
USB Powered
Uses Atmel's 2x5 pin ICSP and 2x3 connector layout
Dimensions: 45x30 mm (1.7x1.2") + 20 cm (8") cable
I add a Picture of it.
PostPosted: Tue Dec 01, 2015 10:19 am    Post subject: Reply with quote
hello,
if you use it to program others AVR you can use it use the classical way (spi pins and reset) to program the arduino micro. but this kind of programmer could erase the bootloader, I'm not the good person to speak about bootloader.
read that before all :
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13061&highlight=olimex
and, in case of trouble , may be you can send a mail to support ?
JP Wink
PostPosted: Tue Dec 01, 2015 9:32 pm    Post subject: Reply with quote
that programmer should work with stk500 native programmer. but i did not test it myself as i do not have that programmer. when it implements sk500v2 it should work.
about the board : did you press reset just before you press F4 to upload?
Petr_
PostPosted: Tue Jan 26, 2016 1:03 pm    Post subject: Reply with quote
Arduino Pro Micro can flash via USB.
Here the program Boot32u4.exe. http://bascomavr.3bb.ru/viewtopic.php?id=1529
This Russian forum. Use google translator.
This arduino module is well suited for tested USB devices using USB Add On or similar USB library.
Petr_
PostPosted: Tue Jan 26, 2016 1:06 pm    Post subject: Reply with quote
del
PostPosted: Tue Jan 26, 2016 3:09 pm    Post subject: Reply with quote
hello
thank you Petr,
I found the program, i'm waiting for one Arduino micro pro
I let you know my experience.
Many thanks
JP Wink
luizabbadia
PostPosted: Fri Jul 07, 2017 2:04 am    Post subject: Reply with quote
OK, little late, but thanks Petr_!!! It worked out for me!!!
View user's profile MSN Messenger
luizabbadia
PostPosted: Fri Jul 07, 2017 5:47 pm    Post subject: Reply with quote
To Petr because I canīt send private.
I liked your forum but for me it is very hard to login because of cyrilic alphabet.
Do you have any workaround for this,please?
luizabbadia
PostPosted: Fri Jul 07, 2017 5:51 pm    Post subject: Reply with quote
Ok,got it! Thanks!!
Petr_
PostPosted: Sat Jul 08, 2017 10:00 am    Post subject: Reply with quote
http://en.bascomavr.3bb.ru/viewtopic.php?id=1529
Download link http://pure-basic.narod.ru/forum_files/bascomavr/Boot32u4.zip
luizabbadia
PostPosted: Sat Jul 08, 2017 4:55 pm    Post subject: Reply with quote
Thanks!
