lnejman
Posted: Mon Nov 30, 2015 11:27 am Post subject: help with Arduino pro Micro |
I have tryed with all the tip and trix for this arduino that i can find , but no luck
This board works fine with Arduino IDE but not with Bascom.
Bascom works with outher Arduino board (UNO rev3).
Have Anyone get Bascom to work with Arduino Pro Micro ??  |
Posted: Mon Nov 30, 2015 4:58 pm Post subject: |
hello,
this Arduino/Genuino is based on a M32U4, with the usb controler and bootloader inside.
Actually Bascom does'nt support it as an ARDUINO
but
Bascom knows the M32U4, this board has an isp port (6pins) so you could use an ISP programmer as the AVRISP MKII
I add a memo (sorry in french but with a lot of pictures,) how to install the AVRISP Programmer (same for studio7)
let me know your progress.
JP
Bon courage
lnejman
Posted: Mon Nov 30, 2015 9:25 pm Post subject: Is this programmer possible to use |
I have purchased a ISP programmer that should be compatible with STK500
Its called Olimex.
Is it possible to use this one??
this is the description:
AVR-ISP500 is a fast and reliable USB AVR programmer, and works directly with AVR Studio. It is recognized as a STK500 programmer and programs all AVRs. It emulates USB CDC so no drivers are required and works under Windows, Linux and MacOS. If you do not want to use AVRStudio you can use AVR-ISP500 with AVRdude.
Features:
Connects to PC via USB 2.0 Full speed
USB Powered
Uses Atmel's 2x5 pin ICSP and 2x3 connector layout
Dimensions: 45x30 mm (1.7x1.2") + 20 cm (8") cable
I add a Picture of it. |
Posted: Tue Dec 01, 2015 9:32 pm Post subject: |
that programmer should work with stk500 native programmer. but i did not test it myself as i do not have that programmer. when it implements sk500v2 it should work.
about the board : did you press reset just before you press F4 to upload? _________________ Mark |
Petr_
Posted: Tue Jan 26, 2016 1:03 pm Post subject: |
Arduino Pro Micro can flash via USB.
Here the program Boot32u4.exe. http://bascomavr.3bb.ru/viewtopic.php?id=1529
This Russian forum. Use google translator.
This arduino module is well suited for tested USB devices using USB Add On or similar USB library.
Petr_
Posted: Tue Jan 26, 2016 1:06 pm Post subject: |
del |
Posted: Tue Jan 26, 2016 3:09 pm Post subject: |
hello
thank you Petr,
I found the program, i'm waiting for one Arduino micro pro
I let you know my experience.
Many thanks
JP  |
luizabbadia
Joined: 11 Dec 2007 Posts: 112 Location: rio de janeiro
Posted: Fri Jul 07, 2017 2:04 am Post subject: |
OK, little late, but thanks Petr_!!! It worked out for me!!! |
luizabbadia
Posted: Fri Jul 07, 2017 5:47 pm Post subject: |
To Petr because I canīt send private.
I liked your forum but for me it is very hard to login because of cyrilic alphabet.
Do you have any workaround for this,please? |
luizabbadia
Posted: Fri Jul 07, 2017 5:51 pm Post subject: |
Ok,got it! Thanks!! |
Petr_
luizabbadia
Posted: Sat Jul 08, 2017 4:55 pm Post subject: |
Thanks! |
