olhexy
Joined: 03 Apr 2011 Posts: 192 Location: Tilburg, Netherlands
Posted: Mon Dec 26, 2016 4:49 pm Post subject: |
@Madf
After install you can read the new Help from within the program. There is a special chapter about what is new/changed in 2080. |
bzijlstra
Posted: Mon Dec 26, 2016 6:25 pm Post subject: History.txt |
It will start with the history.txt |
i.dobson
Joined: 05 Jan 2006 Posts: 1571 Location: Basel, Switzerland
Posted: Wed Dec 28, 2016 7:19 am Post subject: |
Hello Mark,
Thank you for the Christmas present. My large Project (15k lines) compiles and runs as before. The only Problem I'm seeing is with the PDF download tool, it still can't find the PDF's (see attached picture).
PC that Bascom is running on is nothing Special:
Windows 7 64bit
Direct Internet Connection (WLAN -> Router -> Internet) so no Proxy
Regards
Tiny
Joined: 10 Nov 2010 Posts: 110 Location: The Netherlands
Posted: Wed Dec 28, 2016 8:13 am Post subject: |
Hello Mark,
Thankx for the update, but i have some problems.
after install the 2.0.8.0 full version. reformating of the typed tekst doens't work.
and when i type "dim a as " there is no dropdown menu for selecte de variable
regards Tiny |
Posted: Wed Dec 28, 2016 10:33 am Post subject: |
PDF download : just check if port 211 is open in your firewall.
The proxy settings of the PC are used. But port 211 need to be open.
The FTP protocol is used.
- reformat : check if 'reformat code' option is set in the options
- to get a drop down : press CTRL+SPACE. That is also true for CONFIG _________________ Mark |
i.dobson
Posted: Wed Dec 28, 2016 4:17 pm Post subject: |
Port 211 is open, it appears as if Bascom can connect to the server (mail.mcselec.com) but can't get the required data. See attached.
Regards
Tiny
Posted: Wed Dec 28, 2016 8:23 pm Post subject: |
Hello Mark
'reformat code' is set in config
but also when i add comment it is not auto lined when i press enter at the end of the line.
see attachment |
Posted: Wed Dec 28, 2016 9:01 pm Post subject: |
Ian : you can best write to support. This topic is not suited for analyzing the problem.
Tiny : you best send your settings xml file + some test code/project that can demonstrate the problem to support _________________ Mark |
i.dobson
Posted: Wed Dec 28, 2016 9:08 pm Post subject: |
Hi Mark,
No problems. I can live without the PDF updates at the moment. Maybe if I get time I'll get some wireshark dumps of the communication between Bascom and the server.
Regards
Posted: Wed Dec 28, 2016 9:13 pm Post subject: |
Ian : it is best if we figure out the problem. it is probably in the pc config. but it could also be related to the server security settings. _________________ Mark |
plouf
Joined: 19 Jan 2012 Posts: 102 Location: Athens,Greece
Posted: Fri Feb 03, 2017 11:30 pm Post subject: |
a: i do not know where you get that idea? you will loose resolution but it is perfect legal to do so.
Just like : somebyte=someWord
b: maybe read the manual some time? have a look at config submode
and i wonder, what has it to do with 2080? _________________ Mark |
plouf
Posted: Fri Feb 03, 2017 11:50 pm Post subject: |
Hi
a) legal i know but a error , warning or something should be triggered in case it is a mistake !
b) i do not know about submode ! that good, yet again manual says function should be placed before caling the command !
anyway a function can be different decalred (single) and different executed (byte) without a warning ? |
Posted: Sat Feb 04, 2017 2:14 pm Post subject: |
I don`t know how you work but I can say how I work.
At the beginining I don`t like Code Explorer Warrnings and ignore them.
But after time I found that read these tips is useful. Someone take time to write it. Not all this warrnings trigger the errors when compiling but they point somethng you sould check if this is your intention.
If you think that something should trigger the warrning you should write to support like I do.
Sometimes I was problem with code that compiled and work in <2075 and not work obove>2075.
The cause was that variable "Hbyte" is internal Bascom reserved word from >2075 and now compiler generate warrning about that.
So gentle point the problem and this will be done I think.  |
plouf
Posted: Sat Feb 04, 2017 4:59 pm Post subject: |
EDC wrote: | Code Explorer Warrnings and ignore them.
So you tell me that codeexplore , or anyware there was a warning about this ?
can oyou point me please, where is this !?
EDC wrote: | So gentle point the problem and this will be done I think.  |
couldn't actually declare it as "problem" but it "misses to point *MY* error's"
never said that was a bug, but if it is trigger a warnig (as you said) it would help me !
point b in previous post is actually a suugestion !
hope to be clear, and not "offending" because it is not my attitude on this  |
