Alexander-Dan
Posted: Sat Apr 25, 2020 11:14 am Post subject: Hot keys for windows selection |
hi!
my programs are getting longer, the number of lines of code in them is increasing. Therefore, I began to divide the programs into several parts: in one editor window I see the main program loop, in the second window the second part of the code with subprograms is displayed.
Question to the author BASCOM: can you make hot buttons to select the desired window?
If you remember how it was in Norton Commander or FAR: Alt-F1 and Alt-F2 (first and second window selection)
I started working with computers a long time ago, then computers did not have a mouse. So I'm used to working with the keyboard.
(BASCOM-AVR version : 2.0.8.1 ) |
Paulvk
Posted: Sat Apr 25, 2020 11:47 am Post subject: |
When programs get very big I find the Project mode is good
you can divide it into multiple screens
Every sub program can be a separate window
Regards Paul |
Posted: Sat Apr 25, 2020 12:05 pm Post subject: Re: Hot keys for windows selection |
Alexander-Dan wrote: | If you remember how it was in Norton Commander or FAR: Alt-F1 and Alt-F2 (first and second window selection) |
One may remember also how it was in Turbo-Pascal, but that doesn't mean it's useful or in any way standard.
Quote: | I started working with computers a long time ago, then computers did not have a mouse. So I'm used to working with the keyboard. |
If you prefer keys, it's hard to understand why you don't know about the de facto standard Ctrl-Tab.
Works for your case of two open windows nearly as desired. Speed and ease of use is the same, some reprogramming of the cerebral cortex is sufficient.
Alexander-Dan
Posted: Sat Apr 25, 2020 1:17 pm Post subject: Re: Hot keys for windows selection |
MWS wrote: |
...some reprogramming of the cerebral cortex is sufficient. |
phew, how rude, sir.
This function does not work |
Alexander-Dan
Posted: Sat Apr 25, 2020 1:19 pm Post subject: |
Paulvk wrote: | When programs get very big I find the Project mode is good |
Hm ... but how to use this mode? I could not add anything  |
Posted: Sat Apr 25, 2020 1:47 pm Post subject: |
hi Alexander
did you try Tile horizontaly in windows option ?
I use it and as Paul said I use projet mode.
my programs are plitted in .inc parts : see in the left cartrige
JP  _________________ pleasure to learn, to teach, to create |
Evert :-)
Posted: Sat Apr 25, 2020 2:07 pm Post subject: |
1. File -> project -> new
2. Set check @ View -> Project files
3. In the Project view window click op add to add your files
4. Goto 3 until all done
5. File -> project -> save _________________ www.evertdekker.com Bascom code vault |
Alexander-Dan
Thanks! |
Posted: Sat Apr 25, 2020 2:11 pm Post subject: Re: Hot keys for windows selection |
Alexander-Dan wrote: | MWS wrote: |
If a change of habits is not your thing, then you actually need Mark to adapt Bascom to your habits.
Personally I prefer the first option. |
Posted: Sat Apr 25, 2020 2:12 pm Post subject: |
actually, CTRL+F6 selects the next window. (that is normal windows behaviour)
and ALT+W followed by the window number (1,2) will select it direct. _________________ Mark |
Alexander-Dan
Posted: Sat Apr 25, 2020 2:26 pm Post subject: |
albertsm wrote: | actually, CTRL+F6 selects the next window. (that is normal windows behaviour) |
fine!
ps: Oh. My fingers alone do not reach. The left hand is on the keyboard, the right is on the mouse. To switch this combination CTRL+F6, i need to press different buttons with different hands.
albertsm wrote: | ALT+W followed by the window number (1,2) will select it direct. |
I did not understand this.  |
Posted: Sat Apr 25, 2020 2:40 pm Post subject: Re: Hot keys for windows selection |
Alexander-Dan wrote: | This function does not work |
Ah, just noticed, I wrote Shift-Tab, correct is Ctrl-Tab.
This can be easily done with the left hand.
Shift actually has some use in this context too, as together with Ctrl-Tab it lets you cycle the other way around through the tabs.
You need at least three tabs to notice. |
Alexander-Dan
Posted: Sat Apr 25, 2020 3:33 pm Post subject: Re: Hot keys for windows selection |
MWS wrote: |
Ah, just noticed, I wrote Shift-Tab, correct is Ctrl-Tab. |
thanks
haha. I was wrong too
Yes, I know about this button. But I pressed the Alt button instead of Cntrl |
Posted: Tue Apr 28, 2020 9:04 am Post subject: |
Alexander-Dan wrote: | albertsm wrote: | actually, CTRL+F6 selects the next window. (that is normal windows behaviour) |
fine!
it means you need to press ALT + W key at the same time. This will select the Window menu.
Then you press 1, 2 or what ever window you want to select. _________________ Mark |
Alexander-Dan
Posted: Tue Apr 28, 2020 9:07 am Post subject: |
albertsm wrote: | need to press ALT + W key at the same time. This will select the Window menu. |
this is for windows operating system but not for windows of editor BASCOM |
