Atmega 328p How reset by software ?
acjacques
PostPosted: Thu Jun 06, 2019 4:02 am    Post subject: Atmega 328p How reset by software ? Reply with quote
Hi friends;
I am newbie in the AVR world... (coming from PicBasic Pro...)
Did someone have a code that could reset the ATmega 328p by software ?
Thanks for any help
(BASCOM-AVR version : 2.0.8.1 )
Paulvk
PostPosted: Thu Jun 06, 2019 5:02 am    Post subject: Reply with quote
Hello acjacques
I use this to go to the boot vector via a serial port
so I can load new code into the M168 over RS232
if I get 123 sent to the serial port it jumps to the boot vector
Note bascom boot loader sends 123
so this lets me program the M168 remotely without pressing the reset
Regards Paul
 Config Serialin0 = Buffered , Size = 20 , Bytematch = 123
Serial0charmatch:
Cls
Lcd "BOOT VECTOR"
Wait 1
'here you need to read the data sheet
'to find the correct address
Goto &HC00
PostPosted: Thu Jun 06, 2019 7:35 am    Post subject: Reply with quote
Here you have. Now you can add more "AT" commands but this basic code react for "AT+RST".
You can use it for debug/reseting over Bascom,or any other, terminal emulator , or even use it with MCS Bootloader.
$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 64
$swstack = 16
$framesize = 64
$baud = 115200
Const Buffs_len = 50
'*         CONFIG BUFFERED USART FOR DEBUG via USB               *
 Config Serialin0 = Buffered , Size = Buffs_len             'RX from Terminal
  Dim Char As Byte , Cmd_timeout1 As Byte , Got_str As Byte
  Dim Command1 As String * Buffs_len
  Open "COM1:" For Binary As #1
  Const Usb = 1
'*                   TIMER2 FOR TIME BASE                        *
  Config Timer2 = Timer , Prescale = 1024 , Clear_timer = 1
  Compare2a = 155                                           '10ms @16MHz/1024
'*                      VARIABLES                                *
 'general purposes
 Dim Tempb As Byte
'|      PROGRAM START         |
 Enable Interrupts                                          ' for serial receiving in the background interrupt
   '--[ USART0 COM1 USB ]------------------------
    If 0 < Ischarwaiting(#usb) Then
      Char = Inkey(#usb)
      Select Case Char
       Case 10 : Got_str = 1
       Case 13 :                                            'swallow
       Case Else
        Command1 = Command1 + Chr(char)
      End Select
      If Len(command1) > 49 Then Got_str = 1                'force parsing
      If Got_str = 0 Then Cmd_timeout1 = 50                 '50x10ms
      'end if Ischarwaiting
   '--[ PARSE COM1 USB ]-------------------------
    If Got_str = 1 Then
        Tempb = Instr(command1 , "AT+RST")
        If Tempb > 0 Then
          Print #usb , "Reseting in progress..."
          Disable Interrupts
          Config Watchdog = 16                              'set shortest time
          Start Watchdog                                    'always strt WD after config
          Do : Loop                                         'wait for reset in neverending loop
         Got_str = 0
       Command1 = ""
     Cmd_timeout1 = 0
    '--[ TIMER2 10ms ]----------------------------
    If Tifr2.ocf2a = 1 Then
     Tifr2.ocf2a = 1
     'COM1 USB
     If Cmd_timeout1 > 0 Then
      Decr Cmd_timeout1
       If Cmd_timeout1 = 0 Then
        'Got_str = 1                                        'force parsing
         Command1 = ""                                      'or clear trash
PostPosted: Thu Jun 06, 2019 9:01 am    Post subject: Reply with quote
When I want to restart a prog , I use goto 0
look at the help
"Besides using a label you can also specify an address. GOTO &H0000 would jump to the reset vector of the processor. "
JP Wink
PostPosted: Thu Jun 06, 2019 11:51 am    Post subject: Reply with quote
A GOTO 0 or GOTO _RESET is a soft reset. It will just start the code from the start. It will not put the hardware registers in their default.
Using the watchdog like EDC demonstrates is a hard internal reset. This does reset the hardware registers too.
aphawk
PostPosted: Fri Jun 07, 2019 10:53 pm    Post subject: Reply with quote
acjacques,
Hi my friend, I wrote one tutorial with many examples in Bascom to newbies, here in Brazil :
https://www.clubedohardware.com.br/forums/topic/937085-projetos-com-avr-design-programa%C3%A7%C3%A3o-em-basic-e-assembly/
You can download my tutorial with more than 150 pages, with Proteus simulations too, in Portuguese language.
Paulo
acjacques
PostPosted: Sat Jun 08, 2019 10:57 pm    Post subject: Reply with quote
aphawk wrote:
acjacques,
Paulo
Prezado Antonio Paulo Hawk;
Obrigado pelo tutorial. Bem interessante e útil.
Tenho alguma experiencia prévia em PICBasic Pro. Estou usando placas Arduino Nano que săo bem praticas por incluir o conversor USB e poder programar com Bootloader.
ACJacques
acjacques
PostPosted: Thu Jun 20, 2019 8:56 pm    Post subject: Reply with quote
Dear friends;
Using
if resetcommand = 1 then
Wdtcsr = &B11111111
endif
in my code it do a reset in about 2 seconds, but it will not start again unless repowering the device.
I have wrote
Wdtcsr = 0
in the begining of my code but it seems not work
Have I miss some code ?
I am using a bootloader
Atmega328p
