Subs are missing in the code explorer
Climber
PostPosted: Fri Mar 06, 2015 9:16 pm    Post subject: Subs are missing in the code explorer Reply with quote
Hi ,
sometime, existing subs from the program apper not in the code explorer.
i use bascom 2.0.7.8.003.
is this a bug in bascom or do i make a mistake ?
Many greetings
Climbi
PostPosted: Fri Mar 06, 2015 9:23 pm    Post subject: Reply with quote
when you can reproduce it, send the code (zipped) to support. it could be a bug. But in many cases, the problem is incorrect syntax. For example when using reserved words. An indication that there is something wrong with your code can be that indent lines are not drawn properly.
Climber
PostPosted: Sat Mar 07, 2015 7:56 pm    Post subject: Reply with quote
Hi mark,
now i explored the point "Errors" in the code explorer.
There i see a lot of Errors, but it is possible to compile the code without errors.
Now i try to understand and improve the shown errors.
For example i find out that i can not write "If A => B Then... ". I must write "If A >= B...."
I mean "If A => B Then..." works, but it is displayed as an error in the code explorer.
Anyway: Many of the displayed errors i don't understand.
Example:
Const Timer_preload = 11                'Timervorgabe für 1/4 Sekunden Takt  (Timer2 8 Bit)
Config Clock = User
Config Date = Dmy , Separator =  Slash
Config Timer2 = Timer , Prescale = 1024
On Timer2 Sectic
Timer2 = Timer_preload
Enable Timer2
In the line "Timer2 = Timer_preload" i get the error "Expression type mismatch"
But despite all the errors in the code explorer: My cod works fine .Rolling Eyes
Many greetings
Climber
PostPosted: Mon Mar 09, 2015 10:26 pm    Post subject: Reply with quote
the error branch from code explorer is just a beta feature which was enabled because it *can* be useful.(see help). But it can give many errors which are no real errors. mainly because the dat files are missing special options.
while the next release will be a small maintenance release to fix some bugs, the version after that will deal with dat files/errors from code explorer.
Climber
PostPosted: Tue Mar 10, 2015 11:54 am    Post subject: Reply with quote
Hi Mark
after i changed "If A => B Then.... to "If A >= B Then..." i received much less errors in the code explorer.
And then..... all subs are shown in the code explorer.
So far everything is good for me.
Many greetings
Climber
