Climber
Posted: Fri Mar 06, 2015 9:16 pm Post subject: Subs are missing in the code explorer |
Hi ,
sometime, existing subs from the program apper not in the code explorer.
i use bascom 2.0.7.8.003.
is this a bug in bascom or do i make a mistake ?
Many greetings
Climbi
Posted: Fri Mar 06, 2015 9:23 pm Post subject: |
when you can reproduce it, send the code (zipped) to support. it could be a bug. But in many cases, the problem is incorrect syntax. For example when using reserved words. An indication that there is something wrong with your code can be that indent lines are not drawn properly. _________________ Mark |
Climber
Posted: Mon Mar 09, 2015 10:26 pm Post subject: |
the error branch from code explorer is just a beta feature which was enabled because it *can* be useful.(see help). But it can give many errors which are no real errors. mainly because the dat files are missing special options.
while the next release will be a small maintenance release to fix some bugs, the version after that will deal with dat files/errors from code explorer. _________________ Mark |
Climber
Posted: Tue Mar 10, 2015 11:54 am Post subject: |
Hi Mark
after i changed "If A => B Then.... to "If A >= B Then..." i received much less errors in the code explorer.
And then..... all subs are shown in the code explorer.
So far everything is good for me.
Many greetings
Climber |
