Search Find Autocomplete
dl7sep
PostPosted: Tue Jan 27, 2015 6:56 pm    Post subject: Search Find Autocomplete Reply with quote
Search Find Auto Complete
This option can enable/disable the auto completion in the Find dialog. When it is active and you type some text, based on historical input, the text will be completed. This is not always desired and can be disabled.
This will not running on a win7 - 64 Bit System. So i have changed both, XP to WIN7, and Bascom 2.0.7.0 to 2.0.8.0.
On the old system, when i type a varable or select case and so on, i get a info on the screen of the complete variable or what i must type in for select case...
What can i do, do get this beautiful function to run?
Many thanks
Sepp
PostPosted: Wed Jan 28, 2015 12:27 am    Post subject: Reply with quote
Well i have win 7 64 bit and it works ok.
But odd is that you have 2080 ? This means you must be from the future Very Happy
this option works on the Search dialog. I think what you mean is context sensitive help?
you need to press ctrl+space for that. Only Dim has an auto pop up.
dl7sep
PostPosted: Thu Jan 29, 2015 10:43 pm    Post subject: Reply with quote
Hello Mark,
you are right I live in the future, but 2.0.8.0 is my mistake, I mean 2.0.7.8
What I'm searching for, I have some screenshots, with the old Version 2.0.7.7 I hope it is clear what I mean.
Thank you,
Regards Josef
PostPosted: Thu Jan 29, 2015 10:49 pm    Post subject: Reply with quote
yes, but as i wrote : you need to press ctrl+space then you get a pop up. please read the help topic 'running bascom-avr' and the intellisense to be specific.
Meister
PostPosted: Thu Jan 29, 2015 11:01 pm    Post subject: Reply with quote
Type a space and then Strg together with space.
However, after gosub the subs are missing. Instead, labels wrongly are offered.
Regards, Meister
PostPosted: Thu Jan 29, 2015 11:10 pm    Post subject: Reply with quote
that is because you should NOT gosub to a sub , only to a label.
type in call and then press ctrl+space, you get the user subs you can call.
dl7sep
PostPosted: Thu Jan 29, 2015 11:28 pm    Post subject: Reply with quote
Ok, many thanks, now it is clear for me how to do with Strg and space.
Thanks for your good support, Josef
Meister
PostPosted: Fri Jan 30, 2015 3:02 pm    Post subject: Reply with quote
Mark,
How does that comply with this from help:
Unlike normal SUB programs called with the GOSUB statement....
Doesn't the help suggest that GOSUB can be used to "call" a subroutine?
Regards, Meister
PostPosted: Fri Jan 30, 2015 3:22 pm    Post subject: Reply with quote
You should quote the complete phrase from the help : "Unlike normal SUB programs called with the GOSUB statement, the CALL statement enables you to pass variables to a SUB routine that may be local to the SUB."
Also, this is described under the help for CALL.
The phrase 'sub programs' does not mean a procedure like sub/end sub, but a sub routine or program.
gosub should only be used with a label that ends with a RETURN. And you can not pass parameters.
call should be used with a sub procedure.
While you can use gosub/call on subs/routines that pass not parameters, it is best to use the correct syntax.
