Problem with SPI and ISD1730
Ajaxelectronic
PostPosted: Sat Apr 26, 2014 10:10 pm    Post subject: Problem with SPI and ISD1730 Reply with quote
Hi
i involving with ISD1730 in 1 week. but i can't run it.
i read its datasheets and wrote some code, but it can't run ISD1730. please help me.
my code :
$regfile = "m8adef.dat"
$crystal = 8000000
$hwstack = 64
$swstack = 64
$framesize = 64
$baud = 9600
Config Portb.2 = Output
Cs Alias Portb.2
Config Spi = Hard , Interrupt = Off , Data Order = Lsb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 16 , Noss = 1
Spiinit
Waitms 200
Set Cs
Waitms 10
Dim Retry As Byte , N As Byte , Getinput As Byte
Dim D(10) As Byte
Dim Strg As String * 8
Declare Sub Spi_txrx
Declare Sub Power_up
Declare Sub Power_down
Declare Sub Rd_status
Declare Sub Show_msg
Declare Sub Rec
Declare Sub Clr_int
Declare Sub Play
Declare Sub Stp
Declare Sub Eras
Declare Sub Dev_id
Declare Sub Rst
Print "**Start**"
Power_up
  Show_msg
  Input "?" , Getinput
  Power_up
  Select Case Getinput
   Case 1
     Play
     Clr_int
   Case 2
     Power_up
   Case 3
     Power_down
   Case 4
     Stp
   Case 5
     Rec
     Clr_int
   Case 6
     Eras
   Case 7
     Rst
   Case 8
     Dev_id
   Case Else
     Print "Not in Case statement"
  End Select
'Device Power up
Sub Power_up
  D(1) = &H01 : D(2) = &H00
  Reset Cs
  Waitus 2
  Spiout D(1) , 2
  Spiin D(1) , 2
  Waitus 2
  Set Cs
  Print "SR0 Byte1:" ; Bin(d(1)) ; " = A2,A1,A0,INT,EOM,PU,Full,CMD_Err"
  Print "SR0 Byte2:" ; Bin(d(2))
  If D(1).0 = 0 Then                                        'Check CMD_Err
    Print "Power_up OK"
    Print
    Retry = 0
    Waitms 200
    Clr_int
   Else
     Incr Retry
     Waitms 300
     Print "Power_up NOT OK, Retry... : " ; Retry
     Print
     Power_up
End Sub
'Device Power down
Sub Power_down
  D(1) = &H07 : D(2) = &H00
  Reset Cs
  Waitus 2
  Spiout D(1) , 2
  Waitus 2
  Set Cs
End Sub
'Read Device-ID
Sub Dev_id
  N = 3
  D(1) = &H09 : D(2) = &H00 : D(3) = &H00
  Spi_txrx
  If D(1).2 = 1 Then
   Print "Reading Dev_id ok"
   Print "DEVID    :" ; Bin(d(3))                           'valid ID
   Print
  Else
   Print "Reading Dev_id fail"                              'oder CMD_Error?
   Print "Would Be :" ; "01000000"
   Print
End Sub
'Play
Sub Play
  N = 2
  D(1) = &H40 : D(2) = &H0
  Spi_txrx
  If D(1).0 = 0 Then                                        'Check CDM-Err
    Print "Playing..."
      Waitms 100
      N = 3
      D(1) = &H05 : D(2) = &H00 : D(3) = &H00
      Spi_txrx
      Waitms 20
    Loop Until D(1).4 = 1                                   'Check INT
    Clr_int
   Else
    Waitms 200
    Print "occur an err in Play, Retry..."
    Print
    Play
End Sub
'erase
Sub Eras
  N = 2
  D(1) = &H42 : D(2) = &H00
  Spi_txrx
  If D(1).4 = 1 Then
    Waitms 100
    Print "Stop Complete"
    Clr_int
End Sub
'Record
Sub Rec
  N = 2
  D(1) = &H41 : D(2) = &H00
  Spi_txrx
    Waitms 100
    Print "Recording..."
    Print
    Clr_int
   Else
    Waitms 200
    Print "occur an err in Rec, Retry..."
    Print
    Rec
End Sub
'stop
Sub Stp
  N = 2
  D(1) = &H02 : D(2) = &H00
  Spi_txrx
  If D(1).4 = 1 Then                                        'Check INT
    Waitms 100
    Print "Stop Done"
    Print
    Clr_int
   Else
    Waitms 100
    Print "occur an err in Stop, Retry..."
    Print
    Stp
End Sub
'Device reset
Sub Rst
  N = 2
  D(1) = &H03 : D(2) = &H00
  Spi_txrx
End Sub
'clear INT & EOM
Sub Clr_int
  N = 2
  D(1) = &H04 : D(2) = &H00
  Spi_txrx
  If D(1).4 = 0 Then
    Print "Clr_Int Done"
    Print
    Rd_status
   Else
     Waitms 200
     Clr_int
     Print "Clr_Int Retry..."
     Print
End Sub
'Read SR1
Sub Rd_status
  N = 3
  Spi_txrx
  If D(3).0 = 1 Then
    Print "Device Ready"
    Print
   Else
     Waitms 200
     Print "Device Not Ready, Retry..."
     Print
     Rd_status
  Portb.1 = 1
  Waitms 200
  Portb.1 = 0
End Sub
'SPI
Sub Spi_txrx
 Reset Cs
 Waitus 2
 Spiout D(1) , N
 Spiin D(1) , N
 Waitus 2
 Set Cs
End Sub
Sub Show_msg
Print
Print "***************** DEMO ISD1700 over SPI ***********************"
Print
Print "1 Play              2 Power Up"
Print "3 Power Down        4 Stop"
Print "5 Record            6 Erase"
Print "7 Reset             8 Device ID"
Print
End Sub
also i used from flowchart in datasheets in page of 60. i attached it.
www.mrkelectronic.blogfa.com
Best Regards
View user's profile Visit poster's website Yahoo Messenger
Evert :-)
PostPosted: Sun Apr 27, 2014 12:57 pm    Post subject: Reply with quote
When using the Noss option you need to setup the CS pin after the config SPI , but before the spiinit.
$baud = 9600
Cs Alias Portb.2
Set Cs
Spiinit
Waitms 200
Ajaxelectronic
PostPosted: Sun Apr 27, 2014 3:19 pm    Post subject: Reply with quote
Thanks Evert
i try it. but my code don't work yet! Sad
Best Regards
kimmi
Moderator
PostPosted: Sun Apr 27, 2014 5:57 pm    Post subject: Reply with quote
what DEVID do you get ?
Some of the IISD1730 read DEVID 1760 (10100000) rather than 1730 (10000000)
/ Kim
View user's profile Visit poster's website MSN Messenger
Ajaxelectronic
PostPosted: Mon Apr 28, 2014 8:48 am    Post subject: Reply with quote
thanks kimmi
i successfull finaly! the below code working good, this is demo and i wrote it with combination several code from the web and ISD1700 datasheets of course.
all things is ok, but the LED sometimes don't blink! i don't know! also PLAY statement run 2 time for me! i don't have any idea for it!
i complete this code and share it.
new code :
'         In The Name Of GOD
'Topic  : ISD1700 Driver Demo
'Author : Morteza Rahimi Kordmahalle (MRK)
'Microcontroller : ATmega8A
'Compiler : BASCOM 2.0.7.6
'Creation Date : Apr 28, 2014 ( 1393.02.08 )
'Copyright : (C) 2014 By www.mrkelectronic.blogfa.com
$crystal = 8000000
'$crystal = 8000000
$hwstack = 64
$swstack = 64
$framesize = 64
$baud = 9600
'$baud = 4800
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Configurations ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Config Spi = Hard , Interrupt = Off , Data Order = Lsb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 64 , Noss = 0
Spiinit
Waitms 200
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Variables ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Dim D(10) As Byte
Dim Rdy As Bit
'~~~~~~~~~~~~~~~~~~~~~~~~~~~ Declare Subroutines ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Declare Sub Set_rec
Declare Sub Clr_int
Declare Sub Set_play
Declare Sub Stp
Declare Sub Set_eras
Declare Sub Dev_id
Declare Sub Rst
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Initializations ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Print "**Start**"
Power_up
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Main Program ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  Show_msg
  Input "your code >: " , Getinput
  Print
   Case 1
     Set_rec
     Clr_int
   Case 2
     Stp
     Clr_int
   Case 3
     Set_play
     Clr_int
   Case 4
     Set_eras
     Clr_int
   Case 5
     Power_up
     Clr_int
   Case 6
     Power_down
   Case 7
     Rst
     Clr_int
   Case 8
     Dev_id
   Case 9
     Rd_status
   Case Else
     Print "Not Valid Code!"
  End Select
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~  Subroutines ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
'Device Power up
Sub Power_up
  Waitus 2
  Spiout D(1) , 2
  Spiin D(1) , 2
  Waitus 2
  Print "SR0 Byte1: A2  A1  A0  INT  EOM  PU  Full  CMD_Err"
  Print "SR0 Byte1: " ; D(3).7 ; "   " ; D(3).6 ; "   " ; D(3).5 ; "    " ; D(3).4 ; "    " ; D(3).3 ; "   " ; D(3).2 ; "    " ; D(3).1 ; "     " ; D(3).0
  Print
  Print "SR0 Byte2: Address Byte > " ; Bin(d(2))
  Print
  If D(1).0 = 0 Then                                        'Check CMD-Err
    Print "Power_up OK"
    Print
    Retry = 0
    Waitms 200
    Clr_int
   Else
     Incr Retry
     Waitms 300
     Print
     Power_up
End Sub
'Device Power down
Sub Power_down
  Waitus 2
  Spiout D(1) , 2
  Waitus 2
  Print "Power Down..."
  Print
End Sub
'Read Device-ID                   'Maximum Address Value for ISD1730 is &H0FF
Sub Dev_id
  Rd_status
  N = 3
  Spi_txrx
  If D(3) <> 0 Then
    Print "DEVID : " ; Bin(d(3))
    Print
   Else
    Print "Device Not Recognize!!?"
    Print
End Sub
'Read SR0 & SR1
Sub Rd_status
  N = 3
  Spi_txrx
  Waitms 200
  If D(3).0 = 1 Then
    Rdy = 1
    Print
   Else
     Waitms 500
     Rdy = 0
     Print
     Rd_status
  Print "SR1: SE3 SE2 SE1 SE0 Rec Play Erase RDY"
  Print "SR1:  " ; D(3).7 ; "   " ; D(3).6 ; "   " ; D(3).5 ; "   " ; D(3).4 ; "   " ; D(3).3 ; "   " ; D(3).2 ; "     " ; D(3).1 ; "    " ; D(3).0
  Print
End Sub
'Play
Sub Set_play
  If Rdy = 0 Then Rd_status
  N = 7
  D(1) = &H90 : D(2) = &H00 : D(3) = &H10 : D(4) = &H00 : D(5) = &HFE : D(6) = &H00 : D(7) = &H00
  Spi_txrx
    Waitms 200
    Print "Playing..."
    Rdy = 0
    Clr_int
   Else
    Waitms 200
    Print
    Set_play
End Sub
'erase
Sub Set_eras
  N = 7
  D(1) = &H92 : D(2) = &H00 : D(3) = &H10 : D(4) = &H00 : D(5) = &HFE : D(6) = &H00 : D(7) = &H00
  Spi_txrx
    Waitms 200
    Print "Erase Complete"
    Rdy = 0
    Clr_int
   Else
     Waitms 200
     Print "occur an err in Erase, Retry..."
     Print
     Set_eras
End Sub
'Record
Sub Set_rec
  N = 7
  D(1) = &H91 : D(2) = &H00 : D(3) = &H10 : D(4) = &H00 : D(5) = &HFE : D(6) = &H00 : D(7) = &H00
  Spi_txrx
    Waitms 200
    Print
    Rdy = 0
   Else
    Waitms 200
    Print
    Set_rec
End Sub
'Stop
Sub Stp
  N = 2
  Spi_txrx
    Waitms 200
    Print "Stop Done"
    Print
   Else
    Waitms 200
    Print
    Stp
End Sub
'Device reset
Sub Rst
  N = 2
  Spi_txrx
    Waitms 200
    Print "Reset Done"
    Print
    Rdy = 0
   Else
    Waitms 200
    Print "occur an err in Reset, Retry..."
    Print
    Rst
End Sub
'clear INT & EOM
Sub Clr_int
  N = 2
  Spi_txrx
  If D(1).4 = 0 Then
    Print
   Else
     Waitms 200
     Clr_int
     Print
End Sub
'SPI
Sub Spi_txrx
 Waitus 2
 Spiout D(1) , N
 Spiin D(1) , N
 Waitus 2
End Sub
Sub Show_msg
Print
Print
Print "1 Record           2 Stop"
Print "3 Play             4 Erase"
Print "5 Power Up         6 Power Down"
Print "9 RD_Status : Read SR0 and SR1   "
Print
End Sub
[/code][/quote]
Best Regards
PostPosted: Mon Apr 28, 2014 10:21 am    Post subject: Reply with quote
nice Very Happy
one thing : when using NOSS=1 , you MUST set the SS pin to output. Even if you do not use it. Otherwise when it picks up a 1 the hardware will be set to slave mode. That is something of the avr hardware.
i would recommend to set the port pin before the config spi.
Ajaxelectronic
PostPosted: Thu May 01, 2014 11:40 am    Post subject: Reply with quote
thanks albert
i share my work in the below topic :
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&p=64384#64384
Best Regards
