Ajaxelectronic
Posted: Sat Apr 26, 2014 10:10 pm Post subject: Problem with SPI and ISD1730 |
Hi
i involving with ISD1730 in 1 week. but i can't run it.
i read its datasheets and wrote some code, but it can't run ISD1730. please help me.
my code :
Code: |
$regfile = "m8adef.dat"
$crystal = 8000000
$hwstack = 64
$swstack = 64
$framesize = 64
$baud = 9600
Config Portb.2 = Output
Cs Alias Portb.2
Config Spi = Hard , Interrupt = Off , Data Order = Lsb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 16 , Noss = 1
Spiinit
Waitms 200
Set Cs
Waitms 10
Dim Retry As Byte , N As Byte , Getinput As Byte
Dim D(10) As Byte
Dim Strg As String * 8
Declare Sub Spi_txrx
Declare Sub Power_up
Declare Sub Power_down
Declare Sub Rd_status
Declare Sub Show_msg
Declare Sub Rec
Declare Sub Clr_int
Declare Sub Play
Declare Sub Stp
Declare Sub Eras
Declare Sub Dev_id
Declare Sub Rst
Print "**Start**"
Power_up
Show_msg
Input "?" , Getinput
Power_up
Select Case Getinput
Case 1
Play
Clr_int
Case 2
Power_up
Case 3
Power_down
Case 4
Stp
Case 5
Rec
Clr_int
Case 6
Eras
Case 7
Rst
Case 8
Dev_id
Case Else
Print "Not in Case statement"
End Select
'Device Power up
Sub Power_up
D(1) = &H01 : D(2) = &H00
Reset Cs
Waitus 2
Spiout D(1) , 2
Spiin D(1) , 2
Waitus 2
Set Cs
Print "SR0 Byte1:" ; Bin(d(1)) ; " = A2,A1,A0,INT,EOM,PU,Full,CMD_Err"
Print "SR0 Byte2:" ; Bin(d(2))
If D(1).0 = 0 Then 'Check CMD_Err
Print "Power_up OK"
Print
Retry = 0
Waitms 200
Clr_int
Else
Incr Retry
Waitms 300
Print "Power_up NOT OK, Retry... : " ; Retry
Print
Power_up
End Sub
'Device Power down
Sub Power_down
D(1) = &H07 : D(2) = &H00
Reset Cs
Waitus 2
Spiout D(1) , 2
Waitus 2
Set Cs
End Sub
'Read Device-ID
Sub Dev_id
N = 3
D(1) = &H09 : D(2) = &H00 : D(3) = &H00
Spi_txrx
If D(1).2 = 1 Then
Print "Reading Dev_id ok"
Print "DEVID :" ; Bin(d(3)) 'valid ID
Print
Else
Print "Reading Dev_id fail" 'oder CMD_Error?
Print "Would Be :" ; "01000000"
Print
End Sub
'Play
Sub Play
N = 2
D(1) = &H40 : D(2) = &H0
Spi_txrx
If D(1).0 = 0 Then 'Check CDM-Err
Print "Playing..."
Waitms 100
N = 3
D(1) = &H05 : D(2) = &H00 : D(3) = &H00
Spi_txrx
Waitms 20
Loop Until D(1).4 = 1 'Check INT
Clr_int
Else
Waitms 200
Print "occur an err in Play, Retry..."
Print
Play
End Sub
'erase
Sub Eras
N = 2
D(1) = &H42 : D(2) = &H00
Spi_txrx
If D(1).4 = 1 Then
Waitms 100
Print "Stop Complete"
Clr_int
End Sub
'Record
Sub Rec
N = 2
D(1) = &H41 : D(2) = &H00
Spi_txrx
Waitms 100
Print "Recording..."
Print
Clr_int
Else
Waitms 200
Print "occur an err in Rec, Retry..."
Print
Rec
End Sub
'stop
Sub Stp
N = 2
D(1) = &H02 : D(2) = &H00
Spi_txrx
If D(1).4 = 1 Then 'Check INT
Waitms 100
Print "Stop Done"
Print
Clr_int
Else
Waitms 100
Print "occur an err in Stop, Retry..."
Print
Stp
End Sub
'Device reset
Sub Rst
N = 2
D(1) = &H03 : D(2) = &H00
Spi_txrx
End Sub
'clear INT & EOM
Sub Clr_int
N = 2
D(1) = &H04 : D(2) = &H00
Spi_txrx
If D(1).4 = 0 Then
Print "Clr_Int Done"
Print
Rd_status
Else
Waitms 200
Clr_int
Print "Clr_Int Retry..."
Print
End Sub
'Read SR1
Sub Rd_status
N = 3
Spi_txrx
If D(3).0 = 1 Then
Print "Device Ready"
Print
Else
Waitms 200
Print "Device Not Ready, Retry..."
Print
Rd_status
Portb.1 = 1
Waitms 200
Portb.1 = 0
End Sub
'SPI
Sub Spi_txrx
Reset Cs
Waitus 2
Spiout D(1) , N
Spiin D(1) , N
Waitus 2
Set Cs
End Sub
Sub Show_msg
Print
Print "***************** DEMO ISD1700 over SPI ***********************"
Print
Print "1 Play 2 Power Up"
Print "3 Power Down 4 Stop"
Print "5 Record 6 Erase"
Print "7 Reset 8 Device ID"
Print
End Sub
also i used from flowchart in datasheets in page of 60. i attached it.
(BASCOM-AVR version : 2.0.7.7 ) _________________ www.mrkelectronic.blogfa.com
Best Regards |
Evert :-)
Posted: Sun Apr 27, 2014 12:57 pm Post subject: |
When using the Noss option you need to setup the CS pin after the config SPI , but before the spiinit.
Code: |
$baud = 9600
Cs Alias Portb.2
Set Cs
Spiinit
Waitms 200
_________________ www.evertdekker.com Bascom code vault |
Ajaxelectronic
Posted: Sun Apr 27, 2014 3:19 pm Post subject: |
Thanks Evert
i try it. but my code don't work yet!  _________________ www.mrkelectronic.blogfa.com
Best Regards |
kimmi
Posted: Sun Apr 27, 2014 5:57 pm Post subject: |
what DEVID do you get ?
Some of the IISD1730 read DEVID 1760 (10100000) rather than 1730 (10000000) _________________ / Kim |
Ajaxelectronic
Posted: Mon Apr 28, 2014 8:48 am Post subject: |
thanks kimmi
i successfull finaly! the below code working good, this is demo and i wrote it with combination several code from the web and ISD1700 datasheets of course.
all things is ok, but the LED sometimes don't blink! i don't know! also PLAY statement run 2 time for me! i don't have any idea for it!
i complete this code and share it.
new code :
Code: |
' In The Name Of GOD
'Topic : ISD1700 Driver Demo
'Author : Morteza Rahimi Kordmahalle (MRK)
'Microcontroller : ATmega8A
'Compiler : BASCOM 2.0.7.6
'Creation Date : Apr 28, 2014 ( 1393.02.08 )
'Copyright : (C) 2014 By www.mrkelectronic.blogfa.com
$crystal = 8000000
'$crystal = 8000000
$hwstack = 64
$swstack = 64
$framesize = 64
$baud = 9600
'$baud = 4800
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Configurations ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Config Spi = Hard , Interrupt = Off , Data Order = Lsb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 64 , Noss = 0
Spiinit
Waitms 200
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Variables ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Dim D (10) As Byte
Dim Rdy As Bit
'~~~~~~~~~~~~~~~~~~~~~~~~~~~ Declare Subroutines ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Declare Sub Set_rec
Declare Sub Clr_int
Declare Sub Set_play
Declare Sub Stp
Declare Sub Set_eras
Declare Sub Dev_id
Declare Sub Rst
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Initializations ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Print "**Start**"
Power_up
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Main Program ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Show_msg
Input "your code >: " , Getinput
Print
Case 1
Set_rec
Clr_int
Case 2
Stp
Clr_int
Case 3
Set_play
Clr_int
Case 4
Set_eras
Clr_int
Case 5
Power_up
Clr_int
Case 6
Power_down
Case 7
Rst
Clr_int
Case 8
Dev_id
Case 9
Rd_status
Case Else
Print "Not Valid Code!"
End Select
'~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Subroutines ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
'Device Power up
Sub Power_up
D (1) = &H01 : D (2) = &H00
Waitus 2
Spiout D (1) , 2
Spiin D (1) , 2
Waitus 2
Print "SR0 Byte1: A2 A1 A0 INT EOM PU Full CMD_Err"
Print "SR0 Byte1: " ; D (3).7 ; " " ; D (3).6 ; " " ; D (3).5 ; " " ; D (3).4 ; " " ; D (3).3 ; " " ; D (3).2 ; " " ; D (3).1 ; " " ; D (3).0
Print
Print "SR0 Byte2: Address Byte > " ; Bin(d (2))
Print
If D (1).0 = 0 Then 'Check CMD-Err
Print "Power_up OK"
Print
Retry = 0
Waitms 200
Clr_int
Else
Incr Retry
Waitms 300
Print
Power_up
End Sub
'Device Power down
Sub Power_down
D (1) = &H07 : D (2) = &H00
Waitus 2
Spiout D (1) , 2
Waitus 2
Print "Power Down..."
Print
End Sub
'Read Device-ID 'Maximum Address Value for ISD1730 is &H0FF
Sub Dev_id
Rd_status
N = 3
D (1) = &H09 : D (2) = &H00 : D (3) = &H00
Spi_txrx
If D (3) <> 0 Then
Print "DEVID : " ; Bin(d (3))
Print
Else
Print "Device Not Recognize!!?"
Print
End Sub
'Read SR0 & SR1
Sub Rd_status
N = 3
D (1) = &H05 : D (2) = &H00 : D (3) = &H00
Spi_txrx
Waitms 200
If D (3).0 = 1 Then
Rdy = 1
Print
Else
Waitms 500
Rdy = 0
Print
Rd_status
Print "SR1: SE3 SE2 SE1 SE0 Rec Play Erase RDY"
Print "SR1: " ; D (3).7 ; " " ; D (3).6 ; " " ; D (3).5 ; " " ; D (3).4 ; " " ; D (3).3 ; " " ; D (3).2 ; " " ; D (3).1 ; " " ; D (3).0
Print
End Sub
'Play
Sub Set_play
If Rdy = 0 Then Rd_status
N = 7
D (1) = &H90 : D (2) = &H00 : D (3) = &H10 : D (4) = &H00 : D (5) = &HFE : D (6) = &H00 : D (7) = &H00
Spi_txrx
Waitms 200
Print "Playing..."
Rdy = 0
Clr_int
Else
Waitms 200
Print
Set_play
End Sub
'erase
Sub Set_eras
N = 7
D (1) = &H92 : D (2) = &H00 : D (3) = &H10 : D (4) = &H00 : D (5) = &HFE : D (6) = &H00 : D (7) = &H00
Spi_txrx
Waitms 200
Print "Erase Complete"
Rdy = 0
Clr_int
Else
Waitms 200
Print "occur an err in Erase, Retry..."
Print
Set_eras
End Sub
'Record
Sub Set_rec
N = 7
D (1) = &H91 : D (2) = &H00 : D (3) = &H10 : D (4) = &H00 : D (5) = &HFE : D (6) = &H00 : D (7) = &H00
Spi_txrx
Waitms 200
Print
Rdy = 0
Else
Waitms 200
Print
Set_rec
End Sub
'Stop
Sub Stp
N = 2
D (1) = &H02 : D (2) = &H00
Spi_txrx
Waitms 200
Print "Stop Done"
Print
Else
Waitms 200
Print
Stp
End Sub
'Device reset
Sub Rst
N = 2
D (1) = &H03 : D (2) = &H00
Spi_txrx
If D (1).0 = 0 Then 'Check CDM-Err
Waitms 200
Print "Reset Done"
Print
Rdy = 0
Else
Waitms 200
Print "occur an err in Reset, Retry..."
Print
Rst
End Sub
'clear INT & EOM
Sub Clr_int
N = 2
D (1) = &H04 : D (2) = &H00
Spi_txrx
If D (1).4 = 0 Then
Print
Else
Waitms 200
Clr_int
Print
End Sub
'SPI
Sub Spi_txrx
Waitus 2
Spiout D (1) , N
Spiin D (1) , N
Waitus 2
End Sub
Sub Show_msg
Print
Print
Print "1 Record 2 Stop"
Print "3 Play 4 Erase"
Print "5 Power Up 6 Power Down"
Print "9 RD_Status : Read SR0 and SR1 "
Print
End Sub
| [/code][/quote] _________________ www.mrkelectronic.blogfa.com
Best Regards |
Posted: Mon Apr 28, 2014 10:21 am Post subject: |
nice
one thing : when using NOSS=1 , you MUST set the SS pin to output. Even if you do not use it. Otherwise when it picks up a 1 the hardware will be set to slave mode. That is something of the avr hardware.
i would recommend to set the port pin before the config spi. _________________ Mark |
Ajaxelectronic
