LCD 20*4, C2004A, on i2C. E, E1, E2 signals and PCF8574 prob
Goto page Previous  1, 2, 3
sasha_1973
PostPosted: Sun Mar 01, 2015 5:30 am    Post subject: Reply with quote
Доброго Здоровья!
Не хочет работать в версии Bascom 2.0.7.8 через шину multi i2c. Не могли бы, Вы глянуть, в чем проблема?
Health to you!
Do not wants to work in version Bascom 2.0.7.8 multi i2c bus. Сould you glance, what is the problem?
Mrshilov
Bascom LCD Guru
PostPosted: Sun Mar 01, 2015 1:10 pm    Post subject: Reply with quote
Try this:
sasha_1973
PostPosted: Sun Mar 01, 2015 3:25 pm    Post subject: Reply with quote
1
Mrshilov
Bascom LCD Guru
PostPosted: Sun Mar 01, 2015 3:53 pm    Post subject: Reply with quote
Library exist.
sasha_1973
PostPosted: Sun Mar 01, 2015 4:40 pm    Post subject: Reply with quote
Mrshilov wrote:
Library exist.
Моя ошибка, библиотеку не туда скопировал, но теперь другая проблема!
Зависает на строке:
Deflcdchar 1 , 12 , 18 , 18 , 12 , 32 , 32 , 32 , 32 'значек градуса
My fault, not the copied library!
Now another problem: hangs on the line
Mrshilov
Bascom LCD Guru
PostPosted: Sun Mar 01, 2015 6:53 pm    Post subject: Reply with quote
Very Happy
sasha_1973
PostPosted: Sun Mar 01, 2015 7:08 pm    Post subject: Reply with quote
Mrshilov wrote:
Very Happy
Огромное СПАСИБО! Вроде заработало.
Thank you so much! It seems to work.
sasha_1973
PostPosted: Sun Mar 01, 2015 8:10 pm    Post subject: Reply with quote
Снова не работает
Again not work
PostPosted: Sun Mar 01, 2015 8:38 pm    Post subject: Reply with quote
sasha_1973 : please write in English. Otherwise you risk that your posts will be removed and your account suspended.
bzijlstra
Bascom Ambassador
PostPosted: Sun Mar 01, 2015 9:09 pm    Post subject: I2c 20x4 LCD... Reply with quote
Have you seen this item
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=12506
Don't know if it is the same LCD, the one on the picture is working for me
Have fun
Ben Zijlstra
sasha_1973
PostPosted: Mon Mar 02, 2015 1:36 am    Post subject: Re: I2c 20x4 LCD... Reply with quote
Have fun
Ben Zijlstra
Thank you, I will try!
Tried, does not work, please tell me what is the reason
sasha_1973
PostPosted: Mon Mar 02, 2015 1:37 am    Post subject: Reply with quote
Added English versions
Mrshilov
Bascom LCD Guru
PostPosted: Mon Mar 02, 2015 3:22 am    Post subject: Reply with quote
sasha_1973 wrote:
Again not work
Not stable error. How it work in hardware?
sasha_1973
PostPosted: Mon Mar 02, 2015 3:24 am    Post subject: Reply with quote
Mrshilov wrote:
sasha_1973 wrote:
Again not work
One by one, as in Proteus.
With that, if you do not use multi i2c, everything is fine!
Один к одному, как и в Протеусе.
При чём, если не использовать мульти i2c, всё отлично!
Page 3 of 3
