sasha_1973
Posted: Sun Mar 01, 2015 5:30 am Post subject: |
Доброго Здоровья!
Не хочет работать в версии Bascom 2.0.7.8 через шину multi i2c. Не могли бы, Вы глянуть, в чем проблема?
Health to you!
Do not wants to work in version Bascom 2.0.7.8 multi i2c bus. Сould you glance, what is the problem? |
Mrshilov
Posted: Sun Mar 01, 2015 1:10 pm Post subject: |
Try this: |
sasha_1973
Posted: Sun Mar 01, 2015 3:25 pm Post subject: |
1
Mrshilov
Posted: Sun Mar 01, 2015 3:53 pm Post subject: |
Library exist. |
sasha_1973
Posted: Sun Mar 01, 2015 4:40 pm Post subject: |
Mrshilov wrote: |
Library exist. |
Моя ошибка, библиотеку не туда скопировал, но теперь другая проблема!
Зависает на строке:
Deflcdchar 1 , 12 , 18 , 18 , 12 , 32 , 32 , 32 , 32 'значек градуса
My fault, not the copied library!
Now another problem: hangs on the line
Deflcdchar 1 , 12 , 18 , 18 , 12 , 32 , 32 , 32 , 32 ' °
Mrshilov
Posted: Sun Mar 01, 2015 6:53 pm Post subject: |
sasha_1973
Posted: Sun Mar 01, 2015 7:08 pm Post subject: |
Mrshilov wrote: |  |
Огромное СПАСИБО! Вроде заработало.
Thank you so much! It seems to work.
sasha_1973
Posted: Sun Mar 01, 2015 8:10 pm Post subject: |
Снова не работает
Again not work
Posted: Sun Mar 01, 2015 8:38 pm Post subject: |
sasha_1973 : please write in English. Otherwise you risk that your posts will be removed and your account suspended. _________________ Mark |
bzijlstra
sasha_1973
Posted: Mon Mar 02, 2015 1:36 am Post subject: Re: I2c 20x4 LCD... |
Thank you, I will try!
Tried, does not work, please tell me what is the reason
sasha_1973
Posted: Mon Mar 02, 2015 1:37 am Post subject: |
albertsm wrote: | sasha_1973 : please write in English. Otherwise you risk that your posts will be removed and your account suspended. |
Added English versions |
Mrshilov
Posted: Mon Mar 02, 2015 3:22 am Post subject: |
sasha_1973 wrote: | Again not work |
Not stable error. How it work in hardware? |
sasha_1973
Posted: Mon Mar 02, 2015 3:24 am Post subject: |
Mrshilov wrote: | sasha_1973 wrote: | Again not work |
One by one, as in Proteus.
With that, if you do not use multi i2c, everything is fine!
Один к одному, как и в Протеусе.
При чём, если не использовать мульти i2c, всё отлично! |
