Last occurrence of a day of the month
KenHorse
PostPosted: Sun Oct 04, 2020 6:22 pm    Post subject: Last occurrence of a day of the month Reply with quote
I've been using the following to determine the nth occurrence of a day of the month and it works well:
Function DayNameCountCurrentMonth() As Byte
  Local Temp_day As Integer
  Local Day_Name_Counter as Byte
  Day_Name_Counter = 1
  Temp_day = _day                                             'here we get a number from 1 to 31 (Current system date).
  Temp_day = Temp_day - 7                                     'previous week
  While Temp_day > 0
    Incr Day_Name_Counter
  Wend
  DayNameCountCurrentMonth = Day_Name_Counter
End Function
This makes it easy to determine, for example, the 3rd Wednesday of the month. Except I need to be able to determine the last occurrence of a day of the month (let's say the last Friday). As some months have 4 weeks and others have 5, well..that's my problem.
PostPosted: Sun Oct 04, 2020 7:38 pm    Post subject: Re: Last occurrence of a day of the month Reply with quote
KenHorse wrote:
I've been using the following to determine the nth occurrence of a day of ethe month and it works well:
The shown function does nothing more than retrieving the n-th week in a month for a certain numbered day, it does not retrieve the name of said day.
'This' for sure not. Possible however in combination with other, not shown functions.
Calculate the date of the 5th occurence, then check if the result's month is the same as the month in request.
If not, the 4th occurence is valid.
I do remember this issue some while ago here in the forum.
Afair there were two competing solutions, my solution was to use Bascom's convert functions.
You may look that up, it provides the desired solution.
