Using .def with same name but different registers in indepen
Micha
PostPosted: Sun Aug 09, 2020 6:58 pm    Post subject: Using .def with same name but different registers in indepen Reply with quote
Hello
I have written 2 small Libs. In both i have defined an alias for a register. But the register are different.
Have a look at these 2 libs:
In lib 1 I've written
[Test1]
   .def rTmp = r18
   Test1:
      LDI rTmp,$11
      RET
[End]
and in the lib 2 I've written:
[Test2]
   .def rTmp = r16
   Test2:
      LDI rTmp,$22
      RET
[End]
In main-program both libs are included with "$LIB".
Wenn I call the routine test1 and test2 only register r18 ist set. Tested with simulator.
It seems so that only 1 alias (.def) ist used, not both.
Can I not use the same alias in diffrernt libs?
Then the Libs are compiled, then it works correct. But not with using the lib-file.
Is it not possible in Bascom?
PostPosted: Sun Aug 09, 2020 8:06 pm    Post subject: Reply with quote
the register def is global so you can not have the same name in multiple libs. that is correct.
Micha
PostPosted: Mon Aug 10, 2020 6:42 am    Post subject: Reply with quote
Ok.
But then .def ist global, why did not occur an Error then a name is already used?
PostPosted: Mon Aug 10, 2020 11:27 am    Post subject: Reply with quote
that is a good question. i will check that.
a redefinition is allowed but a redefinition with a different register should raise an error.
Micha
PostPosted: Tue Aug 11, 2020 3:18 pm    Post subject: Reply with quote
Have you checked that?
Do you need a sample code?
PostPosted: Tue Aug 11, 2020 9:17 pm    Post subject: Reply with quote
yes i checked it. and i changed it.
Micha
PostPosted: Wed Aug 12, 2020 8:33 am    Post subject: Reply with quote
Thank you!
