Sample code for HC-06 or similar Bluetooth module
TSEYFARTH
PostPosted: Wed Jun 17, 2020 10:23 pm    Post subject: Sample code for HC-06 or similar Bluetooth module Reply with quote
Hello all,
Can anyone point me to sample code to use the HC-06 blue tooth module?
Thank you,
Tim
Dave
PostPosted: Wed Jun 17, 2020 11:54 pm    Post subject: Reply with quote
Hello Tim
You don't really need any code to use the HC-06. Once you configure the HC-06 baud rate you just connect to a com port and use Print and Input commands. I use a bluetooth terminal programon my phone to control projects that have bluetooth. If you are trying to connect two micro controllers using bluetooth I don't think the HC-06 can do that but I've read that the HC-05 can.
Here are my notes to configure the HC-06:
I like realterm to send config commands.
'BlueTooth Config Notes:
' TYPE - HC-06
' DEFAULT BAUD -  9600
' DEFAULT NAME -
' DEFAULT PIN  -  1234
' NEW BAUD     -  115200
' NEW NAME     -  clock
' NEW PIN      -  time
'To enable command mode install jumper C next to module.
'Jumper C pulls the EN line high.
'Setup Commands for this project.
'send             return
'AT            -  OK
'AT+NAMEclock  -  OKsetname
'AT+PINtime    -  OKsetPIN or sometimes no return but pin change works anyway.
'AT+BAUD8      -  OK115200
'Other commands.
'send             return
'AT+BAUD4      -  OK9600
'AT+BAUD5      -  OK19200
'AT+BAUD6      -  OK38400
'AT+BAUD7      -  OK57600
'AT+BAUD9      -  OK230400
'AT+BAUDA      -  OK460800
'AT+BAUDB      -  OK921600
'AT+BAUDC      -  OK1382400
Good luck,
Dave
TSEYFARTH
PostPosted: Thu Jun 18, 2020 1:06 am    Post subject: Reply with quote
Thank you Dave!
Tim
