Nextion and Bascom
Goto page Previous  1, 2
PostPosted: Wed Apr 01, 2020 10:14 am    Post subject: Reply with quote
Thank you Mark
I thought it would be simple but I am very low in ASM
Could it be made into a bascom function.
Nexwave Very Happy
I think bascom and nextion make good partners
as bascom has a soft com port it can be used with the Arduino's with one com port
Nextion now has a CRC function I need to learn how to use it
Regards Paul & keep safe
PostPosted: Sat May 02, 2020 1:06 pm    Post subject: Reply with quote
Need to use array greater than 255 so how to with marks code
Worked it out I needed the extended printbin Very Happy
Regards Paul
PostPosted: Mon May 04, 2020 10:21 am    Post subject: Reply with quote
this is the size :
! ldi r24,10 ; size of array
! ldi r25,0
i will post a function later.
PostPosted: Mon May 04, 2020 11:37 am    Post subject: Reply with quote
'size of array in r24 and r25
Sub Copydown(ar() As Byte , Byreg R24 As Word)
   $asm
      Loadadr Ar(1) , Z                                     ; load address into r30 r31
      add r30,r24                                           ; add size
      adc r31,r25
      sbiw r30,1                                            ; adjust
_copydown:
      ld r23, -z                                            ; load byte
      std z+1,r23                                           ; save
      sbiw r24,1                                            ; adjust size counter
      brne _copydown                                        ; till it is zero
   $end Asm
call it like :
Dim Ar(255) As Byte , J As Byte
Ar(1) = 1
Ar(2) = 2
Ar(3) = 3
Ar(4) = 4
Ar(5) = 5
Copydown Ar(1) , 255
For J = 1 To 10
  Print J ; "-" ; Ar(j)
PostPosted: Mon May 04, 2020 11:42 am    Post subject: Reply with quote
Thankyou Mark
I worked out the size of array part but because the light bulb was slow to come on
in my head about printbin needing the =extended to print more than 255 elements
I thought I had it wrong.
Regards Paul
PostPosted: Mon May 04, 2020 11:52 am    Post subject: Reply with quote
Note for wave tool.
When using the Nextion wave for stored data a lot of ram is needed or an SD card
so the M1284p with 16k of ram is my choice.
The 7 inch screen will need up to 800 bytes to store 1 trace
so if 4 were used 3200 bytes.
The data is lost when you change to another screen so it has to be stored.
Regards Paul
PostPosted: Thu May 07, 2020 1:08 pm    Post subject: Reply with quote
Ok I am learning some asm it may not be well written
but as it works, it means I am learning to use it
all suggestions to improve are welcome as then I learn more.
Regards Paul
Sub W_one(byval M As Byte , Byval J As Byte)
Arx = J
   !push r23
   !push r24
   !push r25
   !push r26
   !push r27
   !push r30
   !push r22
Loadadr Wave1(1) , X
!lds r22,{arx}
!cpi r22,1
!breq gogo
Loadadr Wave2(1) , X
!lds r22,{arx}
!cpi r22,2
!breq gogo
Loadadr Wave3(1) , X
!lds r22,{arx}
!cpi r22,3
!breq gogo
Loadadr Wave4(1) , X
!lds r22,{arx}
!cpi r22,4
!brne gone
Gogo:
'Loadadr Wave1(1) , X                                        'first location
! ldi r24,188 ; size of array
! ldi r25,2
!add r26,r24                ; add size
!adc r27,r25
!movw r30,r26               ; copy to Z
!sbiw r30,1 ; adjust
!lp1000:
!ld r23,-z  ; load byte
!st -x,r23
!sbiw r24,1
!brne lp1000
 Gone:
   !pop r22
   !pop r30
   !pop r27
   !pop r26
   !pop r25
   !pop r24
   !pop r23
   Select Case Arx
     Case 1
       Wave1(1) = M
     Case 2
       Wave2(1) = M
     Case 3
       Wave3(1) = M
     Case 4
       Wave4(1) = M
'Wave1(1) = M
Page 2 of 2
