Watchdog Atmega328
balou
PostPosted: Mon Apr 13, 2020 9:55 am    Post subject: Watchdog Atmega328 Reply with quote
Hey,
The maximum time "Watchdog" is 8 sec. (Atmega328).
Want to use "Watchdog" to get an Atmega329p out of "Sleep Mode" after 60 sec.
Is this possible?
Balou.
Bascom-AVR 2.0.8.5
Evert :-)
PostPosted: Mon Apr 13, 2020 11:04 am    Post subject: Reply with quote
Why with the watchdog? can't you use a regular timer.
balou
PostPosted: Mon Apr 13, 2020 11:50 am    Post subject: Reply with quote
Evert,
I want the Atmega328p 60 sec. put to sleep.
And then wake up the program without external interrupt.
Balou
Bascom-AVR 2.0.8.5
PostPosted: Mon Apr 13, 2020 3:10 pm    Post subject: Reply with quote
Yes it is possible in that uC because you can ENABLE WDT (Watchdog Interrupt). It means that after 8s of sleep Watchdog, instead reset uC, at firs will jump into Watchdog Interrupt. Then you can Reset Watchdog, count some variable for +8s and VERY IMPORTANT - ENABLE WDT INTERRUPT AGAIN! Then you can Sleep uC again till 60s Very Happy
Below you have example on Mega328P (UNO) that will flash LED every 10sec.
For safety purpose WDT should not be reenabled in its own interrupt routine because if main program hang then those interrupts will be forever instead reset.
$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 64
$swstack = 16
$framesize = 64
Config Portb.5 = Output : Led Alias Portb.5
Dim Sleep_cnt As Byte
Config Watchdog = 1024                                      ' ~1s"
Start Watchdog
On Wdt Wdt_isr Nosave
 If Sleep_cnt = 0 Then
  Sleep_cnt = 10                                            '10x ~1s
    Set Led : Waitms 50 : Reset Led                            'flash
 Else
   Decr Sleep_cnt
   Enable Wdt
    Config Powermode = Powerdown                            '->uC will go to sleep here
  'here uC will start after wake up
Wdt_isr:
 'dont enable Wdt here
balou
PostPosted: Mon Apr 13, 2020 6:37 pm    Post subject: Reply with quote
Thank EDC,
It works.
Balou.
Bascom-AVR 2.0.8.5
PostPosted: Wed Apr 15, 2020 7:18 pm    Post subject: Reply with quote
good example EDC.
I like it.
