Need Contact to Mrshilov !
MichaelB.
PostPosted: Mon Oct 28, 2019 6:06 pm    Post subject: Need Contact to Mrshilov ! Reply with quote
I have rewritten your ILI9481 Libary to the ILI9486 Display.
I can Initialize the ILI9486 and solved the Problem with the Inverted Colors and can Display BGC Pictures. ( So far i dont need to use Circles, Boxes or Lines ect. and dont care about it )
My only Problem is, when i put 3,3v on the Display, a function is called which filled the entire Display with Blue color, wait 2 sek. and Fill it with Red.
Then it goes to show some BGC Pictures, and Set the >>Column Address Set (2Ah)<< and the >>Page Address Set (2Bh)<< to show the Picture on the given Location.
Then i call a Function that is reset the Collum and Page Ardresses ( a Window Reset if you will ) to the Specs that is shown in the Datasheet of this Display.
When i reset the register for the Page Address Set (2Bh) to 0000h/01DFh, the Blue and Red Colors dont fill the Entire Screen anymore. There is a maybe 20 Pixel Grey Stripe on one side, the Rest is in the Given Color.
Only a hit on the Reset Button of the USB1286 MCU will Set the Display correct Collumn and Page Locations.
This is my Inititialize:
Res_disp = 0
Waitms 5
Res_disp = 1                                                'Hardware Reset
Waitms 120
Data_disp_low = &h10                                        'Sleep in
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Waitms 120
Data_disp_low = &h13                                        ' Display Mode: Normal
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h28                                        'Display Off
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h38                                        ' Idlemode OFF
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h36                                        'Memory Data Access Control: 36 h
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &hC0
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &hB4                                        ' Display Inversion Control (B4h)
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h34                                        ' Tearing Effect Line OFF
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h20                                        ' Display Inversion OFF
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h01
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &hc0                                        'Power setting 1
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h15
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &hB6                                        ' Display Function Control (B6h)
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h00
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h3B
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h51                                        'Write Display Brightness Value (51h)
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &hFF
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h3a                                        ' Interface Pixel Format (3Ah) -- Color Mode = 16 bit
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h55
Rs_disp = 1
Wr_disp = 0
Wr_disp = 1
Data_disp_low = &h11                                        'Sleep Off
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Waitms 120
Data_disp_low = &h29                                        'Display On
Rs_disp = 0
Wr_disp = 0
Wr_disp = 1
Waitms 120
Const Blau = &H00F8                                         ' 0000_0000 -- 1111_1000
Const Rot = &H1F00                                          ' 0001_1111 -- 0000_0000
Const Braun = &hF100
Const Weiss = &hFFFF
