UART Serialout buffer question
Yokablasta
PostPosted: Fri Aug 16, 2019 10:14 pm    Post subject: UART Serialout buffer question Reply with quote
Hello,
I have a project here that reads in strings of serial data, then processes and transmits the strings. Each string has a status header, which tells the cpu what kind of string (how many bytes) we are transmitting. I am using the hardware uart serial output buffer. Most of these strings can be transmitted FIFO, however, there is one class of string that needs to move to the front of the buffer, as soon as the last string is finished transmitting (IE, as soon as the next byte in line is one of the status headers.) I want to insert the high priority string and immediately transmit it. I am not very familiar with how to manipulate the output buffer, or if it is even possible. Can anyone recommend an approach to this?
I was hoping to move the head and tail pointers to the left and right of the string I just placed in the buffer, then once transmitted, move the head and tail back to the original values. Does this sound like the way to do this?
enniom
PostPosted: Sat Aug 17, 2019 5:27 pm    Post subject: Reply with quote
Have you considered OVERLAY on the sections you want to move?
Dim A_str as String * 10 at *BUFFER(xx)* Overlay
Dim B_str as String * 10 at *BUFFER(YY)* Overlay
Dim Temp_astr as String *10
Dim Temp_bstr as String *10
Temp_astr = A_str
Temp_bstr = B_str
A_str = Temp_bstr
B_str = Temp_astr
E
PostPosted: Mon Aug 19, 2019 1:32 pm    Post subject: Re: UART Serialout buffer question Reply with quote
It is, but the result may be a mess, i.e. unreliable, as you do not have full control over the buffer-routines.
If 'last string' is not a misspell, then simply don't print anything else and wait for _RS_TAIL_PTR equals _RS_HEAD_PTR, as then the last byte is sent out.
By printing then the high priority string, it will be sent out immediately.
In case 'last string' should actually tell 'most recent string' while more prints/strings are in the output-buffer, then I do not see how you would know the end of the recent string.
At the moment of print they are strings, numbers, a.s.o., but as soon as in the buffer, it's only one array of data, where the buffered-out routine will stoically send out byte per byte till nothing's left.
It sounds like a good way to chaos.
Yokablasta
PostPosted: Fri Aug 23, 2019 8:21 pm    Post subject: Reply with quote
MWS,
This makes sense, and it answers my question about whether the contents of the output buffer can be examined. If it is the case that once something gets put in the buffer, then it stoically gets worked off, then it sounds like I need to re-examine my approach to using the output buffer. Perhaps instead of printing the data as it happens, I should create a software buffer and prioritize which strings get sent to the output buffer?
