Nextion Display works with bascom
PostPosted: Sat Jul 15, 2017 2:34 pm    Post subject: Nextion Display works with bascom Reply with quote
Hi
Nextion is a HMI system, more than a simple screen, it is both faster, draw its own user interfaces and all this with only 4 wires:
2 for power supply and 2 for serial communication.
In addition to Bascom, I have prepared a ".inc" file with all the sub and useful functions.
The video example shows only part of its possibilities
What impresses most is speed.
and the video
[/img]https://www.youtube.com/watch?v=YcqzFNcBxMw&feature=youtu.be
In add file : a .zip with all you need to start program doc, datasheet font...
Bon courage
JP Wink
aphawk
PostPosted: Sat Jul 15, 2017 7:52 pm    Post subject: Reply with quote
Hi, Duval,
Very nice !!!
Where you bought this display ?
Thanks !
Paulo
PostPosted: Sat Jul 15, 2017 8:30 pm    Post subject: Reply with quote
Hello JP,
I see you progressed very well. Thank you for sharing your project and the nice video demo.
This is indeed a great display for user interface projects. Well that also depends on the price and availability of course Very Happy
It seems simpler to use than the FT8xx series. (which have great speed as well)
PostPosted: Sun Jul 16, 2017 9:49 am    Post subject: Reply with quote
hi,
It is designed ??? and sold by [/url]https://www.itead.cc/[url] It is not a giant company.
The forum is reactive , but the response are sometime a little bit strong... And the help and doc are poor..
The price seems good, 28 for the 3.5" and 62 for the 5" compare to the "normal" 5" plus interface to adjust the voltage 38+5=43. It is a bit more expensive than a normal screen but the difference is reasonable considering the possibilities.
Now I have to do a project with it !
JP Wink [/url]
PostPosted: Mon Nov 12, 2018 3:15 pm    Post subject: Reply with quote
I add all sub for display time and date
A video is available here :https://youtu.be/YryQtV-_AOs
all the files needed are in add file
PostPosted: Mon Nov 12, 2018 8:06 pm    Post subject: Reply with quote
Hello JP,
Nice to see your project here. Thanks for sharing and for making the video. I enjoyed watching it.
PostPosted: Fri Aug 09, 2019 10:45 am    Post subject: Reply with quote
Hello Mr Duval JP (Jean Pierre ? I`m from Poland but I was learn four years French Very Happy) I really like it Very Happy
"Regard la bas, se Philipe , nes pas?" ahahahaha this is the quote from the first page of our primer-french-book Very Happy
To the point
I have 7" K series Nextion and want to comunicate both ways. So I really appreciate your work that`s why I publish here how to parse data from Nextion.
I think this is better, non blocking solution Very Happy
Look how "Overlay" can be used multiple times on one buffer.
This example can be launched on Mega 2560. Nextion on Com2(RX1/TX1) rest like describes "#USB" it will be on RX0/TX0
$regfile = "m2560def.dat"                                   '8K SRAM | 4K EEPROM
$crystal = 16000000
$hwstack = 256
$swstack = 128
$framesize = 256
$baud = 115200
$baud1 = 9600
Debug On
Config Submode = New
Const Max_usb_in_command_len = 50
Const Max_nex_command_len = 50
'*         CONFIG BUFFERED USART FOR DEBUG via USB               *
Config Com1 = 115200 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
 Echo Off
 Config Serialin0 = Buffered , Size = Max_usb_in_command_len       'RX from Terminal
  Dim Char As Byte , Cmd_timeout1 As Byte , Got_str1 As Byte
  Dim Command1 As String * Max_usb_in_command_len
 'Config Serialout0 = Buffered , Size = Max_usb_out_command_len       'TX to the Terminal
  Open "COM1:" For Binary As #1
    Const Usb = 1
'*           CONFIG BUFFERED USART FOR NEXTION                   *
Config Com2 = 9600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
 Config Serialin1 = Buffered , Size = Max_nex_command_len   'RX
  Dim Cmd_timeout As Byte , Got_str As Byte
'unnecessary
  Dim Command As String * Max_nex_command_len
 'Config Serialout1 = Buffered , Size = Max_nex_command_len         'TX
  Open "COM2:" For Binary As #2
   Const Nex = 2
'*                TIMER2 FOR TIME BASE                           *
Config Timer2 = Timer , Prescale = 1024 , Compare_a = Disconnect , Compare_b = Disconnect , Clear_timer = 1
 Compare2a = 155                                            '10ms @16MHz/1024
'BARTek multipurpose
Dim Helpb As Byte , Helpstr As String * 30 , N As Byte , Tempb As Byte , Helpl As Long
Enable Interrupts                                           'buffered USART
Print #usb , "Program restarted"
'NEXTION RETURN DATA                                        LENGTH
Const Invalid_instruction = &H00                            '4
Const Instruction_okay = &H01                               '4
Const Invalid_component_id = &H02                           '4
Const Invalid_page_id = &H03                                '4
Const Invalid_picture_id = &H04                             '4
Const Invalid_font_id = &H05                                '4
Const Invalid_file_operation = &H06                         '4
Const Invalid_crc = &H09                                    '4
Const Invalid_baud_rate = &H11                              '4
Const Invalid_vaweform_id = &H12                            '4
Const Invalid_variable_name = &H1A                          '4
Const Invalid_variable_operation = &H1B                     '4
Const Assignement_failed = &H1C                             '4
Const Eeprom_operation_failed = &H1D                        '4
Const Invalid_parameters_quantity = &H1E                    '4
Const Io_operation_failed = &H1F                            '4
Const Escape_char_invalid = &H20                            '4
Const Variable_name_to_long = &H23                          '4
'return codes valid  in all cases
'00 00 00 FF FF FF =>Nextion starup                          '6
Const Serial_buff_overflow = &H24                           '4
Const Touch_event = &H65                                    '7
' 65 00 01 01 FF FF FF
' |   |  |  event 01=press, 00=release
' |   |  component ID
' |   page number
' touch event
Const Curr_page_num = &H66                                  '5 second byte is page num
Const Touch_awake_coordinate = &H67                         '9
Const Touch_sleep_coordinate = &H68
 'first two bytes is X
 'next two bytes is Y
 'last byte is event 01=press, 00=release
 'eg. 67 00 7A 00 1E 01 FF FF FF
Const String_data = &H70                                    'varied len eg.70 xx xx xx xx xx xx FF FF FF
Const Numeric_data = &H71                                   '8 eg.71 xx xx xx xx FF FF FF  <-4bytes 32bit value, little endian
Const Auto_sleep = &H86                                     '4
Const Auto_awake = &H87                                     '4
Const Nextion_ready = &H88                                  '4
Const Micro_sd_upgrade = &H89                               '4
Const Transp_data_finished = &HFD                           '4
Const Transp_data_ready = &HFE                              '4
Macro Nexend                                                'to end a tx sequence--------------------------
     Printbin #nex , &HFF ; &HFF ; &HFF
End Macro
Macro Nexq                                                  ' to send quote before or after a sentence---------
     Printbin &H22
End Macro
Sub Set_return_level()
  'how much return will be sent over serial
  'LEVEL (2 is default)
  '0=no return command will be sent
  '1=only confirm succes commands
  '2=only if command failed
  '3=all return command from &H00 to &H23 will be sent
   Print #nex , "bkcmd=1";
   Nexend
End Sub
Dim Nex_buff(30) As Byte , Nex_idx As Byte , End_cnt As Byte , Min_len As Byte
Dim New_long As Long At Nex_buff(2) Overlay
Dim New_string As String * 29 At Nex_buff(2) Overlay
'for touch event
Dim Touch_page As Byte At Nex_buff(2) Overlay
Dim Touch_id As Byte At Nex_buff(3) Overlay
Dim Touch_state As Byte At Nex_buff(4) Overlay              '1=press , 0=release
'for coordinates
Dim New_x As Word At Nex_buff(2) Overlay
Dim New_y As Word At Nex_buff(4) Overlay
Call Set_return_level
  '--[ USART0 COM1 USB ]------------------------
  If 0 < Ischarwaiting(#usb) Then
   Char = Inkey(#usb)
    Cmd_timeout1 = 10                                       '
   Select Case Char
    Case 10 : Got_str1 = 1
    Case 13
    Case Else
     Command1 = Command1 + Chr(char)
   End Select
   If Len(command1) > 49 Then Got_str1 = 1
   If Got_str1 = 0 Then Cmd_timeout1 = 50                   '50x10ms
   'end if Ischarwaiting
  '--[ PARSE COM1 USB ]-------------------------
  If Got_str1 = 1 Then
        If 0 < Instr(command1 , "AT+RST") Then
          Print #usb , "Reseting in progress..."
          Config Watchdog = 16
          Start Watchdog
          Do : Loop
        Elseif 0 < Instr(command1 , "AT+ON") Then
           Print #nex , "sendxy=1";
           Nexend
        Elseif 0 < Instr(command1 , "AT+OFF") Then
           Print #nex , "sendxy=0";
           Nexend
      Got_str1 = 0
    Command1 = ""
   Cmd_timeout1 = 0
 '--[ USART1 COM2 nex ]---------------------
  If 0 < Ischarwaiting(#nex) Then
    Incr Nex_idx
     Nex_buff(nex_idx) = Waitkey(#nex)
     Cmd_timeout = 10                                       'unnecessary
    If Nex_idx = 1 Then                                     'check what type of msg we receiving
     Select Case Nex_buff(1)
      Case 0
       'it can be 4bytes Invalid_instruction
       'or 6 bytes Nextion_startup (may be after reset)
        Min_len = 1
      Case Touch_event
        Min_len = 4
      Case Touch_awake_coordinate                           '9 bytes
        Min_len = 6
      Case Touch_sleep_coordinate                           '9 bytes
        Min_len = 6
      Case String_data                                      'it will be string with variable len
        Min_len = 2
      Case Numeric_data                                     'there can be FF`s so we must wait for 8 bytes
        Min_len = 5
      Case Else
        Min_len = 1                                         'rest of return`s have one byte followed three FF`s
     End Select
    Else
                                                        'msg continue
     If Nex_buff(nex_idx) = &HFF Then
      If Nex_idx > Min_len Then
       If End_cnt < 2 Then
        Incr End_cnt
       Else                                                 'we received third FF
'         '-----------------------------[ DEBUG ]----------
'          Debug #usb , "Debug=> ";
'          For N = 1 To Nex_idx
'           Debug #usb , Hex(nex_buff(n)) ; " ";
'          Next
'          Debug #usb , ""
         'parse
           Case Invalid_instruction
            If Nex_idx = 4 Then
             Debug #usb , "Invalid instruction!"
            Elseif Nex_idx = 6 Then
             Debug #usb , "Nextion rebooted OK"
           Case Instruction_okay
             Debug #usb , "Command accepted"
           Case Invalid_variable_name
             Debug #usb , "Variable or component NAME not recognized!"
           Case Touch_event
             If Touch_state = 0 Then
              Debug #usb , "Relased object " ; Touch_id ; " on page " ; Touch_page
             Else
              Debug #usb , "Pressed object " ; Touch_id ; " on page " ; Touch_page
           Case Touch_awake_coordinate To Touch_sleep_coordinate
              Swap New_x                                    'big endian order received
              Swap New_y
              Debug #usb , "Coordinates are: X=" ; New_x ; " Y=" ; New_y
           Case String_data
             Helpb = Nex_idx - 2
             Nex_buff(helpb) = 0                            'add string terminator
             Debug #usb , "New string=> " ; New_string
              'You can parse commands/data here
           Case Numeric_data
             Debug #usb , "New value=> " ; New_long
             'If you expect numeric data from Nextion then it will be here
          End Select
          Nex_idx = 0
          End_cnt = 0
 '--[ TIMER2 10ms ]----------------------------
 If Tifr2.ocf2a = 1 Then
  Tifr2.ocf2a = 1
  If Cmd_timeout1 > 0 Then
   Decr Cmd_timeout1
   If Cmd_timeout1 = 0 Then
     Command1 = ""
  If Cmd_timeout > 0 Then
   Decr Cmd_timeout
   If Cmd_timeout = 0 Then
    Nex_idx = 0
    End_cnt = 0
  '10ms
PostPosted: Fri Aug 09, 2019 2:49 pm    Post subject: Reply with quote
congratulations, I have not managed to operate a nextion with an Arduino
you did it !
I would like you to send me your private email address
I would like to discuss with you on a topic of development
JP yes Jean-Pierre Wink
PostPosted: Fri Aug 09, 2019 3:10 pm    Post subject: Reply with quote
EDC,
I forgot to give me mine : jp030405 at yahoo.fr
JP Wink
Jerry
PostPosted: Wed Nov 27, 2019 5:51 pm    Post subject: Reply with quote
Fantastic work.
I just ordered a 10.1" Nextion display, looking forward to learning how to use. Thank you very much for the information.
PostPosted: Fri Nov 29, 2019 6:50 pm    Post subject: @EDC Reply with quote
hi dear professor EDC Wink
with a arduino2560
your idea to use port 0 as a control screen is great with Debug
but unfortunately I don't understand your program:
we are in an endless Do___loop loop
in my program I open a page and then wait for an event to occur as it is pressed on a window or field
in return I get the device number and the values that correspond to the field. In your program I don't know where to find these indications
example
' get a value from a tool sending a value from byte to long
Function Nex_onevalue(byval Text_id As String) As Long
   Local Gtext As String * 15
   Local Xvalue As Integer
   Local Lvalue As Long
   Local Lvalue2 As Long
   Gtext = "get " + Text_id + ".val"                        'Request The Actual Value
   Print Gtext;
   Nexend                                                   'macro which send &hFF,&hFF,&hFF
   Call Nex_return()
   Xvalue = Tabreturn(3) * 256
   Lvalue = Tabreturn(4) * 65536
   Lvalue2 = Tabreturn(5) * 16777216
   Nex_onevalue = Xvalue + Tabreturn(2)
   Nex_onevalue = Nex_onevalue + Lvalue
   Nex_onevalue = Nex_onevalue + Lvalue2
End Function
do you want to explain to me?
what is timer2 used for?
and where is the sub Set_return_level()
I lost half of my hair Crying or Very sad
JP
