Anyone else have the hardware to check this?
KenHorse
PostPosted: Wed Aug 07, 2019 4:30 pm    Post subject: Anyone else have the hardware to check this? Reply with quote
This code works if compiled under 2.0.8.1 but under 2.0.8.2, it only generates a 1.3 kHz neverending tone on my system. However, the print statement reprints approx. every 23 seconds
$regfile = "m2561def.dat"
$crystal = 16000000
$hwstack = 300
$swstack = 200
$framesize = 100
$baud = 57600
Dim DialString As String * 10
DialString = "12345678"
Print "DialString " ; DialString
DtmfOut DialString , 60
I stumbled across this when 2.0.8.2 broke this in existing code, so I tried the above simple test with the same results
six1
PostPosted: Thu Aug 08, 2019 6:21 am    Post subject: Reply with quote
...same here: https://bascomforum.de/index.php?thread/1702-dtmf-ausgabe-mit-undefinierten-pausepegeln/&postID=28027#post28027
User Mitch64 compiled the mcs.lib and mcs.lbx worked
For technical reasons, the signature is on the back of this message.
KenHorse
PostPosted: Thu Aug 08, 2019 3:40 pm    Post subject: Reply with quote
thank you. Now I just need to translate to English Laughing
PostPosted: Thu Aug 08, 2019 9:07 pm    Post subject: Reply with quote
i checked it and mcs.lbx in the setup is not in sync with mcs.lib.
Use Tools Lib manager to compile mcs.lib
KenHorse
PostPosted: Thu Aug 08, 2019 9:32 pm    Post subject: Reply with quote
Thanks Mark, that did it
