unzeitig
Posted: Mon Jul 29, 2019 4:00 pm Post subject: MODBUS master on XMEGA |
Can somebody explain me why it does not work - it prints ABC only and stay running on Print #1 , Makemodbus(2 , 3 , B , 8); row.
When I try it with MEGA128 - it works properly.
[code]
$regfile = "xm128a3udef.dat"
$hwstack = 64
$swstack = 40
$framesize = 40
$lib "modbus.lbx"
Const Crystalfrekq = 32000000
$crystal = Crystalfrekq
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1 'CPU Clock = 32MHz
Bitwait Osc_status.1 , Set 'Check if 32MHz Oscillator is ready
Bitwait Osc_status.2 , Set 'Check if internal 32.768 KHz Oscillator is ready
Osc_dfllctrl.0 = 0
Dfllrc32m_ctrl.0 = 1 'enable
Config Com1 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "COM1:" For Binary As #1
'dimension some variables
Dim B As Byte
B = &H26
Print #1 , "ABC"
[/code]
[b][color=red](BASCOM-AVR version : 2.0.8.1 )[/b][/color] |
Posted: Tue Jul 30, 2019 11:17 am Post subject: |
it seems the xmega.lib and the modbus.lib got out of sync.
I attached a corrected version. _________________ Mark |
unzeitig
Posted: Tue Jul 30, 2019 11:38 am Post subject: |
Now it works, thank you for fast reply. |
matjazs
Posted: Fri Oct 04, 2024 4:36 pm Post subject: |
I would like to read the data from the energy meter - Energy meter TAC1101 Tariff
[url]admin: ads for ali are not allowed. instead attach the PDF[/url]
ModBUS is used for communication.
I'm using ATXMEGA32 ("xm32a4udef.dat") test board.
Attached is my Bascom example made from Samples file "rs485-modbus-master.bas" and the answer from the PC terminal.
I don't understand how makemodbus really works. I have read the documentation from e-meter and also bascom help,
but somehow I can't connect this information.
Maybe someone can help me and suggest what I should do to be able to read the data from the energy meter.
I would like to read the information:
Power
Voltage
Current
Power factor
Frequency
Wh out
Wh in
Code: | '-----------------------------------------------------------------------------------------
'name : rs485-modbus-master.bas
'copyright : (c) 1995-2020, MCS Electronics
'purpose : demo file for MAKEMODBUS
'micro : XMega32
'ModBUS test program
'ATXMEGA32
'TestBoard-MS
'2024-10
'Energy meter TAC1101 Tariff
'-From Dokumentation-----------------------
'Usage: TAC1100 [-a address] [-d] [-x] [-p] [-v] [-c] [-e] [-i] [-t] [-f] [-g] [-T] [[-m]|[-q]] [-b baud_rate] [-P parity] [-S bit] [-z num_retries] [-j seconds] [-w seconds] device
'TAC1100 [-a address] [-d] [-b baud_rate] [-P parity] [-S bit] -s new_address device
'TAC1100 [-a address] [-d] [-b baud_rate] [-P parity] [-S bit] -r baud_rate device
'TAC1100 [-a address] [-d] [-b baud_rate] [-P parity] [-S bit] -R new_time device
'where
'-a address Meter number (between 1 and 247). Default: 1
'-s new_address Set new meter number (between 1 and 247)
'-p Get power (W)
'-v Get voltage (V)
'-c Get current (A)
'-f Get frequency (Hz)
'-g Get power factor
'-e Get exported energy (Wh)
'-i Get imported energy (Wh)
'-t Get total energy (Wh)
'-T Get Time for rotating display values (0 = no rotation)
'-d Debug
'-x Trace (libmodbus debug on)
'-b baud_rate Use baud_rate serial port speed (1200, 2400, 4800, 9600) Default: 2400
'-P parity Use parity (E, N, O)
'-S bit Use stop bits (1, 2). Default: 1
'-r baud_rate Set baud_rate meter speed (1200, 2400, 4800, 9600)
'-R new_time Change rotation time for displaying values (0 - 30s) (0 = no totation)
'-m Output values in IEC 62056 format ID(VALUE*UNIT)
'-q Output values in compact mode
'-z num_retries Try to read max num_retries times on bus before exiting with error. Default: 1 (no retry)
'-j 1/10 secs Response timeout. Default: 2=0.2s
'-D 1/1000 secs Delay before sending commands (wait line set). Default: 30=0.03s
'-w seconds Time to wait to lock serial port. (1-30s) Default: 0s device Serial device, i.e. /dev/ttyUSB0
$regfile = "xm32a4udef.dat"
$crystal = 32000000
$hwstack = 50
$swstack = 50
$framesize = 50
$lib "modbus.lbx"
Config Print1 = Portb.3 , Mode = Set
Rs485dir Alias Portb.3 'make an alias
Config Rs485dir = Output 'set direction register to output
Rs485dir = 0 ' set the pin to 0 for listening
'Config Modbus = Default
'-Oscilator ----------------------------------------------------------------------
Config Osc = Enabled , Extosc = Enabled , Pllosc = Enabled , Range = 12mhz_16mhz , Startup = Xtal_16kclk , Pllsource = Extclock , Plldiv2 = Disabled , Pllmul = 2 , 32khzosc = Disabled
Config Sysclock = Pll , Prescalea = 1 , Prescalebc = 1_1
'Config Priority = Static , Vector = Application , Lo = Enabled
'Config Submode = New
'-EEPROM XMEGA-----------------------------------------------------------------
'Config Eeprom = Mapped
'-COM Ports ---------------------------------------------------------------------------------
'Serial Interface to PC
'COM----UART----TX pin--RX pin-
'COM1 - UART_C0 PORTC.3 PORTC.2 RS485- ModBUS Energy meter
'COM3 - UART_D0 PORTD.3 PORTD.2 PC-Terminal
'COM5 - UART_E0 PORTE.3 PORTE.2 WiFi ESP8266
Config Com3 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'Config Com5 = 57600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
'--Open all UARTS----------------------------------------------------------------------------------
Open "COM1:" For Binary As #1 'RS485- ModBUS Energy meter
Open "COM3:" For Binary As #3 'PC-Terminal
'Open "COM5:" For Binary As #5 'WiFi ESP8266
Config Serialin = Buffered , Size = 50
Config Serialin2 = Buffered , Size = 50
Print #3 , "*****Energy meter 2024-10*****"
Dim B As Byte
Dim W As Word
Dim L As Long
Dim Str_mbus As String * 20
W = &H4567 'assign a value
L = &H12345678 'assign a value
Main:
Wait 2 ' delay
'Print "send request to slave/server"
' Send one of the following three messages
Print #1 , Makemodbus(1 , 3 , &H2B , 24); ' slave 2, function 3, start address 2B, 4 words is 8 bytes
W = &HDD :
'Print #1 , Makemodbus(1 , 3 , &H64 , W); ' slave 2, function 6, address 8 , value of w
'Print #1 , Makemodbus(2 , 16 , 8 , L); ' slave 2, function 16, address 8 , send a long
While Ischarwaiting() <> 0
B = Waitkey(#1)
Str_mbus = Str_mbus + Hex(b)
Wend
Print #3 , Str_mbus
Str_mbus = ""
'If Ischarwaiting(#1) <> 0 Then 'was something returned?
' B = Waitkey(#1) 'then get it
' Print#3 , Hex(b) ; ","; 'print the info
'End If
End |
Response from the terminal on the computer.
The data looks like random where some information is missing.
Quote: | *****Energy meter 2024-10*****
4025
4020
D009
0C0300
4025
0C2000
012B00
000D00
A025
002000
022B00
000300
012B00
000300
002B00
000300
4025
0C1003
102B00
002003
082B00
002003
matjazs
Posted: Sun Oct 06, 2024 9:14 pm Post subject: |
I fixed some troubles on my hardware.
Now I connected TCA1101 directly to PC and terminal via USB/RS484 converter.
Reading datasheet of TCA1101 I send HEX value:
Quote: | Example: Read “Phase 1 line to neutral volts”
Request: 01 04 00 00 00 02 71 CB
Where, 01 = Meter address
04 = Function code
00 = High byte of registers starting address
00 = Low byte of registers starting address
00 = High byte of registers number
02 = Low byte of registers number
71 = CRC Low
CB = CRC High |
I got response:
04 = Function code
04= Byte count
43 = Data, (High Word, High Byte)
5C = Data, (High Word, Low Byte)
D8 = Data, (Low Word, High Byte)
49 = Data, (Low Word, Low Byte)
B5 = CRC Low
E4 = CRC High |
... which means, that Voltage is:
Quote: | 43 5C D8 49(Hex) = 220.845 (Floating point) |
What is exactly what I need.
Now I read serial output on my board - Sending information to TCA1101:
Code: | Print #1 , Makemodbus(&H01 , &H04 , &H00000002 , &H04); |
and on serial interface appear data:
Quote: | HEX 01 04 00 02 00 02 D0 0B |
.. here must be
Quote: | HEX 01 04 00 00 00 02 71 CB |
Why is Low byte of registers starting address &H02 instead &H00? |
Posted: Mon Oct 07, 2024 2:24 pm Post subject: |
you send &H00000002
that is not the same as the 0000 you sent with the terminal
matjazs
Posted: Mon Oct 07, 2024 2:47 pm Post subject: |
Quote: | you send &H00000002 |
Serial port sends &H 00 02 00 02 (&H 01 04 00 02 00 02 D0 0B)
I don't understand.
Does that mean I'm sending this in two parts:
&H0000 and &H0002 ?
How is this done with makemodbus?
Maybe:
Code: | Print #1, Makemodbus(&H01, &H04, &H0000, &H0002, &H04); |
Posted: Mon Oct 07, 2024 3:16 pm Post subject: |
you send too many parameters.
please check makemodbus in the help. only 4 are allowed. and you specify the start address.
i think that your device is not compatible with modbus. only the crc is. _________________ Mark |
matjazs
Posted: Mon Oct 07, 2024 7:19 pm Post subject: |
Mark. Thank you very much.
One question more:
On response data I get value
How to calculate a floating point value from a hexadecimal value in Bascom
In this case, Quote: | &H43618A75 is 225,541 |
I used this:
https://gregstoll.com/~gregstoll/floattohex/
Maybe some advice. |
Posted: Mon Oct 07, 2024 7:52 pm Post subject: |
that has been asked before. it is simple :
Code: | Dim L As Long
Dim Sn As Single At L Overlay
L = &H43618A75
print sn
matjazs
Posted: Mon Oct 07, 2024 9:26 pm Post subject: |
Thank you very much again.
It's really simple .
The best solutions are always simple. |
