Aliases on array
moreau
PostPosted: Fri Jul 26, 2019 7:29 am    Post subject: Aliases on array Reply with quote
Is the following syntax is ok ?
newname alias array(1,2).7
newname is a single bit.
array is declared before.
Does any one has test this ?
Thank you.
Denis
(BASCOM-AVR version : 2.0.7.8 , Latest : 2.0.8.1 )
six1
PostPosted: Fri Jul 26, 2019 1:13 pm    Post subject: Reply with quote
i wonder, if it is too much work for you, to assemble little test programm...
$regfile = "m8def.dat"                                      ' specify the used micro
$hwstack = 32                                               ' default use 32 for the hardware stack
$swstack = 10                                               ' default use 10 for the SW stack
$framesize = 40                                             ' default use 40 for the frame space
$crystal = 4000000                                          ' used crystal frequency
$sim
dim b_array(2,2) as byte
b_array(1,1) = &B_1100_1010
b_array_1_1_bit_0 alias b_array(1,1).0
b_array_1_1_bit_1 alias b_array(1,1).1
b_array_1_1_bit_2 alias b_array(1,1).2
b_array_1_1_bit_3 alias b_array(1,1).3
b_array_1_1_bit_4 alias b_array(1,1).4
b_array_1_1_bit_5 alias b_array(1,1).5
b_array_1_1_bit_6 alias b_array(1,1).6
b_array_1_1_bit_7 alias b_array(1,1).7
print "Bit 0: ";b_array_1_1_bit_0
print "Bit 1: ";b_array_1_1_bit_1
print "Bit 2: ";b_array_1_1_bit_2
print "Bit 3: ";b_array_1_1_bit_3
print "Bit 4: ";b_array_1_1_bit_4
print "Bit 5: ";b_array_1_1_bit_5
print "Bit 6: ";b_array_1_1_bit_6
print "Bit 7: ";b_array_1_1_bit_7
end
Bit 0: 0
Bit 1: 1
Bit 2: 0
Bit 3: 1
Bit 4: 0
Bit 5: 0
Bit 6: 1
Bit 7: 1
PostPosted: Fri Jul 26, 2019 2:03 pm    Post subject: Reply with quote
Hi Denis,
Could you please explain and post your problem?
What do you want to do?
With bascom you have a tool called SIMULATOR, have you tried it?
jp Wink
moreau
PostPosted: Wed Jul 31, 2019 8:19 am    Post subject: Aliases on array Reply with quote
Thanks for the answer.
To answer why i have not testing a short code, i'm not at home for testing and it was a simple question. Very thanks for answer. I can continue to investigate without my computer to test..
Subject closed, answer is noted 20/20.
Best regards.
D.
