How to print a array?
P_Santos
PostPosted: Thu Jul 25, 2019 5:24 pm    Post subject: How to print a array? Reply with quote
Please try it in Simulator
$baud = 9600 ' use baud rate
$hwstack = 40 ' default use 32 for the hardware stack
Dim Array(5) As Byte
const k = 5
Array(1) = 1 : Array(2) = 2 : Array(3) = 3 : Array(4) = 4 : Array(5) = 5
Print "print array " ; Array(1) ; 5
Print "print array " ; Array(1) ; k
'It not work, what i make wrong
Regards
P_Santos
(BASCOM-AVR version : 2.0.8.1 , Latest : 2.0.8.1 )
MichaelB.
PostPosted: Thu Jul 25, 2019 5:54 pm    Post subject: Reply with quote
The Fastest solution is
Print array(1)
Print array(2)
Print array(3)
Print array(4)
Print array(5)
or
Dim array(5) as byte , A as byte
For A=1 to 5
Print "Print Array" ; array(A)
Embarassed
PostPosted: Thu Jul 25, 2019 7:52 pm    Post subject: Reply with quote
Check topic "Printbin" in the help.
https://wiki.mcselec.com/bavr/PRINTBIN
Printbin Array(1) 'whole array will be sent if not specified
