SSD1306 Oled I2c 0.96 inch
Goto page Previous  1, 2, 3, 4
PostPosted: Mon Aug 29, 2016 10:42 am    Post subject: Reply with quote
many thanks Mrshilov
It is working perfectly and very fast on arduino uno
if you use it remember to put the lib "glcdSSD1306-I2C-Buf.lib" in the directory mcs electronic/bascom avr/lib
jp Wink
gatabi
PostPosted: Wed Dec 14, 2016 7:44 pm    Post subject: Reply with quote
albertsm wrote:
you found out correct. the twi in xmega uses Z. so Z must be saved.
I sent you a driver in support.
Is there any idea on how to use glcdSSD1306-I2C.lib with Xmega? Is there any other library for XMEGA chips?
Meister
PostPosted: Sat Dec 17, 2016 3:58 pm    Post subject: Reply with quote
Same question for
glcdEADOGMXL240-7-I2C.lib with Xmega.
Thanks in advance.
parafka
PostPosted: Thu Aug 23, 2018 7:52 pm    Post subject: Reply with quote
Hello,
I have a problem with compiling the Test SSD1306 buffered.bas (glcdSSD1306-I2C-Buf.lib). I have Bascom 2.0.8.0.
I threw the library glcdSSD1306-I2C-Buf.lib into C: \ Program Files (x86) \ MCS Electronics \ BASCOM-AVR \ LIB,
Open from glcdSSD1306-I2C-Buf.zip Test SSD1306 buffered.bas, press F7 and...
error:
Error : 1 Line : -2003 Unknown statement [RCALL _UPDATE_SCREEN] , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\GLCDSSD1306-I2C-BUF.LIB
Could someone compile the Test SSD1306 buffered.bas in the latest Bascom?
https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=download&id=3783
thank you
Mrshilov
Bascom LCD Guru
PostPosted: Thu Aug 23, 2018 9:38 pm    Post subject: Reply with quote
All strings "RCALL _UPDATE_SCREEN" in library must be changed to "gosub _UPDATE_SCREEN".
parafka
PostPosted: Thu Aug 23, 2018 10:08 pm    Post subject: Reply with quote
Compilation without errors!
Thank you.
sielcon
PostPosted: Mon Sep 03, 2018 11:29 pm    Post subject: Problem SSD1306 IIC Buffered Lib Reply with quote
Hello Mrshilov, how are you? I'm starting to use your library with buffer, and obviously it's much faster, in addition to having excellent graphics commands.
I just have a problem, set LCD_AUTO = 0 and it is true that the display does not show anything properly, after executing Gosub _update_screen it shows it but the screen remains as if it were in LCD_AUTO = 1, with a very fast but annoying blink, Probe with LCD of .96 and with 2.42 and does the same.
You have some idea of what mistake I may be making.
Here the video https://www.dropbox.com/s/pq00xcfkzpdwrku/VID_20180903_183352.mp4?dl=0
Thank you so much.
Best regards.
sielcon
PostPosted: Tue Sep 04, 2018 5:44 pm    Post subject: Reply with quote
Solved the problem, change in the LIB the values of initialization by those of the LIB without buffer and the flicker decreased to logical values.
Thanks also.
Best regards.
Page 4 of 4
