Joined: 03 Oct 2004 Posts: 238 Location: Gothenburg, Sweden
Posted: Tue Jan 16, 2018 12:13 am Post subject: Stepper motor driver running as background process
Time for a small but perhaps useful contribution.
Hope you can make use of it
/Per
'********************** STEP MOTOR DRIVING for Arduino Mega2560 and PBL3717 ****************************
This program drives a stepper motor by an interrupt driven background process. One microstep per interrupt
A fully autonomous session consist of Ramp_up -> Constant speed for N microsteps -> Ramp_down
Any type of 2-phase stepper motor may be used. 4,8,16 or 32 microsteps per physical motor cycle may be specified. This is equivalent to 1,2,4 or 8 microsteps per motor step
A stepping sequence can range from -2^31 to +2^31 microsteps (See STEPPER MOTOR PARAMS here below)
Each stepping sequence will ramp up and down from a safe start rate, for smoother start/stop
It is written for Arduino Mega 2560 interfacing a PBL3717 (NJR3717) or equivalent power IC, but should be rather easy to adapt to other IC's.
A simple command line interpreter will accept commands over a serial port
The whole stepping sequence is strated by calling the STEPP routine. It will start background stepping and then return.
The Tim1_irq interrupt routine will take care of the actual stepping
SYNTAX: CALL STEPP(<steps> , <rate>)
Where <steps> may be -2^31 to +2^31 microsteps
and <rate> may be R to XTAL microsteps/sec, but as TIMER1 is just 16 bits long, there is a lower limit to R
This lower rate limit is R=XTAL/65535 microsteps/s and is automatically checked by the STEPP routine
The upper rate limit is XTAL microsteps/s, but this is of course an unrealistic rate for any motor...
Stepping will automatically wait until previous stepping is finished (or cancelled by user)
Stepping will start from a safe rate (S). Then ramp up to final sustained rate (R)
Two PBL3717 ICs are needed. On for each winding. (see attached schematic)
The Arduino Mega 2560 interface is like this:
Vref_a/b is controlling the amount of power for each microstep via a PWM acting as a DAC (Sine wave approximated power)
Phase_a/b is controlling currents direction in the coils during a full microstep sequence
Phase_a Alias Portl.0 'Arduino pin 49
Phase_b Alias Portl.1 'Arduino pin 48
I0_a Alias Portl.2 'Arduino pin 47
I0_b Alias Portl.3 'Arduino pin 46
Vref_a Alias Portl.4 'Arduino pin 45
Vref_b Alias Portl.5 'Arduino pin 44
I1_a Alias Portl.6 'Arduino pin 43
I1_b Alias Portl.7 'Arduino pin 42
TCC1 is used for control of the stepping rate
TCC5 is used for Motor power control. It acts as a PWM-DAC for the sine wave microstepping
Thank you for sharing your work. This is a great piece of code. Wish i had that some years ago when i had to figure it out
I see that you also included an AN about the LC filter. Interesting. _________________ Mark
