RFID Reader
Goto page Previous  1, 2, 3
yamaja
PostPosted: Fri Oct 30, 2015 7:07 am    Post subject: Reply with quote
i.dobson wrote:
Hi Hkipnik,
Thanks for the code, I'll try it out when I get the time.
I wanted to write my own code but I've sent most of my time getting the i2c bootloader working.
Regards
Ian Dobson
Hi Ian.
Nice to met you. any update from you if you have successfully using i2c communication ?
and a big thanks for Hkipnik. for such a great code. i have try it and successful.
by the way, dear all
are there any clue how to use multiple rfid module RC522 in one single microcontroller ?
i need to use 4 rfid module in 1 micocontroler.
the 4 rfid module communication & database are same.
Alexander-Dan
PostPosted: Wed Jun 07, 2017 6:37 pm    Post subject: Reply with quote
Hkipnik wrote:
Hello,
here is a Demo to read and write Data to the Tag.
Best regards
Hkipnik
Hkipnik,
Do you experience the use of chips ultralight and ultralight c ?
Do you used chips ultralight? you have experience using these cards?
sielcon
PostPosted: Mon Oct 23, 2017 4:27 pm    Post subject: Reply with quote
Hi Hkipnik, excellent work. I consult you, I need to read the ID of cards ultralight C, does not recognize them, it would have to modify some parameters for this.
Thank you very much.
Hkipnik
PostPosted: Tue Oct 24, 2017 6:17 pm    Post subject: Reply with quote
Hello,
here again an update for read 7 byte tag ID
Best regards
Hkipnik
sielcon
PostPosted: Tue Oct 24, 2017 8:42 pm    Post subject: Reply with quote
Hello Hkipnik, thank you very much for uploading version 1.12, I commented that I am trying to read an ultralight C and does not recognize it in the sub IS_CARD place a print to see what value came BACKLEN and comes with 2 instead of 16, not if you know what the inconvenience may be, from now on thank you very much.
Best regards.
Hkipnik
PostPosted: Thu Nov 02, 2017 7:26 pm    Post subject: Reply with quote
Hello,
found this post
https://forum.mikroe.com/viewtopic.php?f=147&t=64203
I then changed L1 and L2 and now the UID ultralight C card can be read out.
Best regards
Hkipnik
sielcon
PostPosted: Thu Nov 02, 2017 7:54 pm    Post subject: Reply with quote
Great thank you very much.
Page 3 of 3
