Lookup using variable?
KenHorse
PostPosted: Mon Sep 11, 2017 4:31 pm    Post subject: Lookup using variable? Reply with quote
According to the HELP, you can use a variable for the LABEL when using LOOKUP.
"You may also use a variable that holds the address of a label."
Take the following code as an example:
Dim TempString As String   * 30
Dim TempInt As Integer
Dim Index As Integer
  Index =10
  TempString = "EEPROM1"
  TempInt = LOOKUP(Index , TempString)
  Print "TempInt " ; TempInt
EEPROM1:
Data 1% , 2% , 3% , 4% , 5% , 6% , 7% , 8% , 9% , 10% , 11% , 12% , 13% , 14% , 15% , 16% , 17% , 18% , 19% , 20% , 21% , 22% , 23% , 24%
TempInt returns a -1
Instead of using a string, I tried this instead:
Dim TempInt2 As Integer
  Index =10
 TempInt2 = 3
  TempInt = LOOKUP(Index , TempInt2)
1:
And this returns 6144
What am I doing wrong?
KenHorse
PostPosted: Mon Sep 11, 2017 4:37 pm    Post subject: Re: Lookup using variable? Reply with quote
  Index =10
EEPROM1:
  Index =10
 TempInt2 = 1
1:
six1
PostPosted: Tue Sep 12, 2017 6:51 am    Post subject: Reply with quote
"Address of a Label" can be done with LOADLABEL
KenHorse
PostPosted: Tue Sep 12, 2017 3:43 pm    Post subject: Reply with quote
I'm not sure that's what I'm looking for as I'm not using the $EEPROM directive
But since I'm using a Mega2561, even if it is, I guess I can't do this (Help says it only works for <=64K memory AVRs)
Oh well.....
PostPosted: Tue Sep 12, 2017 3:49 pm    Post subject: Reply with quote
it should work with >64K also.
lookup was enhanced later to support this.
KenHorse
PostPosted: Tue Sep 12, 2017 3:53 pm    Post subject: Reply with quote
Doesn't seem to work in the simulator:
Dim A As Integer
Index = 5
TempInt = LOOKUP(Index , A)
EEPROM1:
A = Loadlabel(EEPROM1)
This returns -27368
PostPosted: Tue Sep 12, 2017 8:07 pm    Post subject: Reply with quote
doesnt surprise me Very Happy
why did you put this : A = Loadlabel(EEPROM1) at the bottom?
you should load the value BEFORE you use the variable A.
KenHorse
PostPosted: Tue Sep 12, 2017 8:15 pm    Post subject: Reply with quote
Point 1 - doesn't matter where I put it, it still doesn't work for me
Point 2 - the HELP says (and shows):
Loadlabel will only work for processors with <= 64KB memory.
If you use Loadlabel on an EEPROM label (a label used in the $EEPROM data area) , these labels must precede the Loadlabel function.
This would be ok :
$eeprom ' eeprom image
label1:
data 1,2,3,4,5
label2:
data 6,7,8,9,10
$data ' back to normal mode
dim w as word
w=loadlabel(label2)
This code will work since the loadlabel is used after the EEPROM data labels.
Sorry Mark but this is confusing
PostPosted: Tue Sep 12, 2017 9:58 pm    Post subject: Reply with quote
you did not specified the version you use. I use 2080.
so if you use an older version it will not work with >64K.
loadlabel loads the address of a label into a variable.
you could pass this to lookup()
lookup does not work on eeprom data.
you mix up 2 things from the help.
the working code is this :
Dim A As Integer
Index = 5
EEPROM1:
in the loadlabel help text , there is a remark that when you load the address of a label in EEPROM, you must place the eeprom data before the loadlabel. this because eeprom data is not actual data that ends up in flash but in a file you can use to program the eeprom.
KenHorse
PostPosted: Tue Sep 12, 2017 10:15 pm    Post subject: Reply with quote
Dim A As Integer
Index = 5
EEPROM1:
Sorry, using 2.0.7.9 (don't see a license file for 2.0.8.0)
PostPosted: Tue Sep 12, 2017 10:18 pm    Post subject: Reply with quote
my working code will also work for 2079, just not when data is located in pages other than the first.
there is no lic file for 2080, only a full setup.
KenHorse
PostPosted: Tue Sep 12, 2017 10:23 pm    Post subject: Reply with quote
Got it, thanks
