select-case-end select
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions
Printpix52
PostPosted: Sat Apr 29, 2017 2:20 am    Post subject: select-case-end select Reply with quote
Hi All!!
ADC converts the input voltage level to a number in the range of 0 to 1023 of the 8 values to turn on the corresponding LED 900, 800, 700, 600, 500, 400, 200, 102 .
Why do you mark me error ? Rolling Eyes
$regfile = "m16adef.dat"
$crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 19200
Config Portb = Output : Lightlevel Alias Portb : Portb = &B11111111
Config Pina.0 = Input
Start Adc
Dim Lightlevel As Word
  Lightlevel = Getadc(0)
  Select Case Lightlevel
   Case Is > 102 : Portb = &B01111111
   Case Is > 200 : Portb = &B10111111
   Case Is > 400 : Portb = &B11011111
   Case Is > 500 : Portb = &B11101111
   Case Is > 600 : Portb = &B11110111
   Case Is > 700 : Portb = &B11111011
   Case Is > 800 : Portb = &B11111101
   Case Is < 900 : Portb = &B11111110
  End Select
six1
PostPosted: Sat Apr 29, 2017 8:21 am    Post subject: Reply with quote
try it this way...
$crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 19200
Start Adc
   Case 102 To 199 : Portb = &B01111111
   Case 200 To 399 : Portb = &B10111111
   Case 400 To 499 : Portb = &B11011111
   Case 500 To 599 : Portb = &B11101111
   Case 600 To 699 : Portb = &B11110111
   Case 700 To 799 : Portb = &B11111011
   Case 800 To 899 : Portb = &B11111101
   Case 900 To 1023 : Portb = &B11111110
  End Select
For technical reasons, the signature is on the back of this message.
Printpix52
PostPosted: Sat Apr 29, 2017 3:13 pm    Post subject: Reply with quote
Thanks friend.. Error!!! Confused Confused
[/img]
Printpix52
PostPosted: Sun Apr 30, 2017 3:42 am    Post subject: Reply with quote
Hello all!!
Before:
After:
Ddrb = 255                                                  'Salida
Portb = 255                                                 'Led apagado (STK500)
Wink Wink Wink
enniom
PostPosted: Sun Apr 30, 2017 8:26 pm    Post subject: Reply with quote
Either you, your code or both are confused.
Printpix52
PostPosted: Sun Apr 30, 2017 9:30 pm    Post subject: Reply with quote
Helo!!ENNIOM...
$crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 19200
Ddrb = &B11111111 : Portb = &B11111111                      'portb ouput , pullup high
Config Adc = Single , Prescaler = Auto , Reference = Avcc   ' 5v
'Cap 100N On Aref To Gnd
'avcc to +5v
Start Adc
   End Select
Very Happy Very Happy
Printpix52
PostPosted: Sun Apr 30, 2017 9:34 pm    Post subject: Re: select-case-end select Reply with quote
Printpix52 wrote:
Hi All!!
$crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 19200
Start Adc
  End Select
corrected....
$crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 19200
'avcc to +5v
Start Adc
      Case Is > 950 : Portb = &B01111111
      Case Is > 900 : Portb = &B10111111
      Case Is > 800 : Portb = &B11011111
      Case Is > 700 : Portb = &B11101111
      Case Is > 500 : Portb = &B11111011
      Case Is > 300 : Portb = &B11111101
      Case Is < 150 : Portb = &B11111110
   End Select
Wink Wink Wink Wink
bzijlstra
Bascom Ambassador
PostPosted: Sun Apr 30, 2017 11:57 pm    Post subject: Alias and variabele... Reply with quote
Before you had lightlevel as alias for Portb (8 bit) but also as variabele dimmentioned as Word (16 bit). Think there was your problem. Correct me if I am wrong.
Have fun
Ben Zijlstra
Printpix52
PostPosted: Mon May 01, 2017 4:18 am    Post subject: Reply with quote
Hello bzijlstra!!!
Very good question.
The variable used for this program is word size, ie 2 bytes (16 bits) because the values of the analog to digital converter is 0-1023.
six1
PostPosted: Mon May 01, 2017 1:02 pm    Post subject: Reply with quote
another way is to shift right by 2 lightlevel... without selct case...
Printpix52
PostPosted: Mon May 01, 2017 4:13 pm    Post subject: Reply with quote
Hello Six!!
See how it works out? Confused
six1
PostPosted: Tue May 02, 2017 6:02 am    Post subject: Reply with quote
if you divide the ADC Value by 4, you will get a byte value... (1024 / 4 = 256)
Dividing by 4 is the same than shifting right by 2
Shift Lightlevel  , Right , 2
Portb = Lightlevel
so your whole code looks like this:
$crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 19200
Start Adc
  Portb = Lightlevel
Printpix52
PostPosted: Tue May 02, 2017 1:07 pm    Post subject: Reply with quote
Hi six1!!
It works but it's not the same friend !! Very Happy Very Happy
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-AVR Unsupported versions All times are GMT + 1 Hour
