Arduino Leonardo as a password storage device in a PS/2-line
MZ+78-TtY3
PostPosted: Sun Mar 26, 2017 9:18 am    Post subject: Arduino Leonardo as a password storage device in a PS/2-line Reply with quote
Hello,
I am new to Bascom-AVR.
My project is to add the Arduino Leonardo in a PS/2-line to use it as a password storage device.
Is there any Bascom-AVR code already published ?
ICould it be possible to drive it using a 4x4 keypad ?
Thanks in advance
Regards
Theo
PostPosted: Sun Mar 26, 2017 6:00 pm    Post subject: Reply with quote
Hi Theo,
Welcome here !
look at the help from Bascom about PS/2 : CONFIG ATEMU
unfortunately : The PS2 Keyboard and mouse emulator needs an additional commercial addon library.
https://www.mcselec.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=35&category_id=6&option=com_phpshop&Itemid=1
Bon courage
JP Wink
MZ+78-TtY3
PostPosted: Sun Mar 26, 2017 6:41 pm    Post subject: Password storage device Reply with quote
Hi JP
Thanks for the reply.
When I started the project I have made a program using the Arduino IDE as I found in the web that a serial output i.e via USB is only possible with the Arduino Leomardo (Atmega32u4).
But the Leonardo can only send one letter in the used program as I noticed. Therefore I bought the Bascom-compiler to solve the problem.
Is it possible to use the buffer to read out serially a string containing 8 password letters ? Afterwards it has to be send serially via RS232 which can be converted by hardware.
Regards
Theo
PostPosted: Mon Mar 27, 2017 10:36 am    Post subject: Reply with quote
I use Arduino Uno and arduino M2560, so I don't know very well leonardo, but I see in the Arduino site :
The Leonardo has a number of facilities for communicating with a computer, another Arduino, or other microcontrollers. The ATmega32U4 provides UART TTL (5V) serial communication, which is available on digital pins 0 (RX) and 1 (TX).
and I know Basic Bascom is a complete program with a lot of possibilities for serial communications. and with a long help file Wink you must spend time to learn ! Confused
see the help for "using uart" you can follow the sample about buffer data
the Ischarwaiting() instruction is very powerfull to fill an array of chr.
I use it like that :
another µP send a sentence stating by Chr(254) and stop with Chr(255)
Sentence = "" : Kbyte = 1 : Serialflag = 0
Open "com3:" For Binary As #1
If Ischarwaiting(#1) = 1 Then
Jbyte = Waitkey(#1)
If Jbyte = 254 Then
Serialflag = 1
If Serialflag = 1 Then
If Jbyte = 255 Then
Clear Serialin3 ' note the Clear statement !!!
Close #1
Exit Do
Tabdate(kbyte) = Jbyte 'i fill a array
Kbyte = Kbyte + 1
L1byte = L1byte + 1
loop
then you can fill a sentence with text = mid (........, J, 1)
Take care, in serial communication, we work in Ascii code .
take care about chr(13) chr(10)
use the ";" after print : print "bonjour"; ' print without chr(13 and chr(10)
JP
