Pzx
Posted: Wed Aug 17, 2016 6:55 pm Post subject: Watchdog fuse bit |
Hello, I would like to use Watchdog always on fusebit to be more safe and independent from unexpected software crash, but it seems not work properly.
My test program is very simple:
Config Watchdog = 1024
Start Watchdog
Reset Watchdog
Toggle LED
Waitms 1
With Watchdog controlled by software fuse bit selected everything is ok, but when I select Watchdog always on fuse bit the program doesnt work. Why? What is missing in the code then?
Evert :-)
Pzx
Posted: Wed Aug 17, 2016 9:23 pm Post subject: |
ATMEGA 2560 |
i.dobson
Joined: 05 Jan 2006 Posts: 1571 Location: Basel, Switzerland
Posted: Thu Aug 18, 2016 7:32 am Post subject: |
Could it be that the avr is taking too long to initialise and going into watchdog reset?
Maybe try using the $INITMICRO macro to reset the watchdog during init. Something like:
Code: |
$INITMICRO
Start Watchdog
Reset Watchdog
Toggle LED
Waitms 1
_init_micro:
Reset Watchdog
Maybe the AVR is taking too long to clear the ram, so also try $NORAMCLEAR (You'll need to handle setting all your variables to a defined value yourself)
Regards
Pzx
Posted: Thu Aug 18, 2016 8:59 am Post subject: |
Hi Ian, you are right Atmega seems to be in permanent reset state,
unfortunately your code doesnt help much.
Any other ideas? |
Posted: Thu Aug 18, 2016 9:11 am Post subject: |
This micro have even 8s Watchdog(look into datasheet page 66). Try another higher value.
Wait 1 + Toggle can be more than 1024 WD timer
You can also try Waitms 500->Reset WD ->Waitms 500 -> Reset WD + Toggle LED ..and so on if value 1024 is the best for you.
EDIT. Look attached picture.
I often open DAT files and search for interested me values by typing CTRL + F
Here I type WD and voila  |
i.dobson
Posted: Thu Aug 18, 2016 9:30 am Post subject: |
Looking through the data sheet, I couldn't find anything on what value will be used for the watchdog reset timer on power up (before the user code starts).
Regards
Evert :-)
Posted: Thu Aug 18, 2016 9:48 am Post subject: |
If you are using the watchdog with the WDTON fuse you can not change the watchdog registers anymore easy. (Has to be done with in 4 clock cycles)
This is done to prevent that the software accidentally alter the registers.
It's not clear how Bascom handles this and if Bascom takes the setting of the fuse bit in consideration.
Are you using a bootloader? _________________ www.evertdekker.com Bascom code vault |
O-Family
Posted: Thu Aug 18, 2016 10:20 am Post subject: |
This is $initmicro instruction after the execution, would initialize the Watchdog to a minimum of 16ms, I think that it is a bug in the BASCOM.
Only get fixed in the mark, there is not means.
Code: |
00072 : EF8F RESET: LDI R24,$FF
00073 : BF8D OUT SPL,R24
00074 : EEC0 LDI YL,$E0
00075 : EEE8 LDI ZL,$E8
00076 : 2E4E MOV R4,ZL
00077 : E281 LDI R24,$21
00078 : BF8E OUT SPH,R24
00079 : E2D1 LDI YH,$21
0007A : E2F1 LDI ZH,$21
0007B : 2E5F MOV R5,ZH
0007C : 940E 00AA CALL L000AA ;$initmicro
0007E : 95A8 WDR ;Watchdog of Reset
0007F : B784 IN R24,MCUSR
00080 : 2E08 MOV R0,R24
00081 : 7F87 ANDI R24,$F7
00082 : BF84 OUT MCUSR,R24
00083 : E188 LDI R24,$18
00084 : 2799 CLR R25
00085 : 9380 0060 STS WDTCSR,R24
00087 : 9390 0060 STS WDTCSR,R25 ;### Watchdog => 16ms ###
00089 : EFEE LDI ZL,LOW(S1FFE)
0008A : E1FF LDI ZH,HIGH(S1FFE)
0008B : E0A0 LDI XL,LOW(S0200)
0008C : E0B2 LDI XH,HIGH(S0200)
0008D : 2788 CLR R24 ;All clear of SRAM
0008E : 938D L0008E: ST X+,R24
0008F : 9731 SBIW ZH:ZL,1
00090 : F7E9 BRNE L0008E
If there is no need to clear all of the SRAM, or initialize it yourself, please put the $noramclear instruction.
Code: |
$noramclear
Posted: Thu Aug 18, 2016 1:23 pm Post subject: |
i.dobson wrote: | Looking through the data sheet, I couldn't find anything on what value will be used for the watchdog reset timer on power up (before the user code starts) |
Default value in WDTCSR for WDP3..0 is 0000, this results in a timeout of 16ms.
O-Family wrote: | Only get fixed in the mark, there is not means. |
Would you mind to write in English?
@TO:
There are two issues imho:
1) the clear-ram and startup code takes about 50000 processor cycles. If the processor is running at 8 MHz, it is done in a bit more than 6ms, fast enough to reset the watchdog within 16ms.
In case the processor runs slower, it may run into a endless watchdog reset loop while clearing ram.
2) looking at the Config Watchdog routine, it is messed up somehow, it does weird things and looks unusable to me.
A correct version according the data sheet would look like:
Code: | !IN R22, SREG ' save status of global interrupts
!CLI ' disable interrupts
!IN R23, MCUSR ' get processor status register
!CBR R23, 2^WDRF ' clear watchdog reset flag
!OUT MCUSR,R23 ' save it to status register
!LDI R25, 2^WDE+2^WDP3+2^WDP0 ' have new prescaler ready
!LDS R24, WDTCSR ' get watchdog control register
!ORI R24, 2^WDCE+2^WDE ' enable change
!STS WDTCSR, R24 ' save
!STS WDTCSR, R25 ' write new prescaler well within 4 cycles
!OUT SREG, R22 ' restore global interrupt status |
You can try and paste this code instead of Config Watchdog = 1024
My version 2.0.7.8 |
Pzx
Posted: Thu Aug 18, 2016 7:21 pm Post subject: |
Hello, thanks for all your replays
Same more claryfication regarding my hardware:
no Bootloader
external 16MHz cristal oscilator
Also I find interesting info in the Atmel ATMEGA2560 pdf in the Watchdog Timer section:
(There is also timming issue about 4 clock cycles like Evert wrote before)
The Watchdog always on (WDTON) fuse, if programmed, will force the Watchdog Timer to System Reset mode.
With the fuse programmed the System Reset mode bit (WDE) and Interrupt mode bit (WDIE) are locked to 1 and 0
respectively. To further ensure program security, alterations to the Watchdog set-up must follow timed sequences.
The sequence for clearing WDE and changing time-out configuration is as follows:
1. In the same operation, write a logic one to the Watchdog change enable bit (WDCE) and WDE. A logic one
must be written to WDE regardless of the previous value of the WDE bit.
2. Within the next four clock cycles, write the WDE and Watchdog prescaler bits (WDP) as desired, but with
the WDCE bit cleared. This must be done in one operation.
There is also some asm code example:
WDT_off:
; Turn off global interrupt
cli
; Reset Watchdog Timer
wdr
; Clear WDRF in MCUSR
in r16, MCUSR
andi r16, (0xff & (0<<WDRF))
out MCUSR, r16
; Write logical one to WDCE and WDE
; Keep old prescaler setting to prevent unintentional time-out
ldi r16, WDTCSR
ori r16, (1<<WDCE) | (1<<WDE)
sts WDTCSR, r16
; Turn off WDT
ldi r16, (0<<WDE)
sts WDTCSR, r16
; Turn on global interrupt
sei
ret
Im not sure what to do with this code. Is it watchdog configure code only or is it reset Watchdog procedure that I should run periodicly? Can I then use normal Reset Watchdog Bascom function? Unfortunately I am not familiar with asm (thats why I am using Bascom ) so how to implemant this asm code into my Bascom test code?. |
Posted: Thu Aug 18, 2016 7:58 pm Post subject: |
Pzx wrote: | Im not sure what to do with this code. |
For example learn from it?
Quote: | Is it watchdog configure code only or is it reset Watchdog procedure that I should run periodicly? |
What would the name of the routine WDT_off: tell you about it's purpose?
Quote: | Can I then use normal Reset Watchdog Bascom function? |
Sure.
Quote: | Unfortunately I am not familiar with asm |
You also have some more problems to open your eyes, LOL.
Quote: | so how to implemant this asm code into my Bascom test code?. |
If you'd actually succeed to implement this asm code, you would end trying to switch off a watchdog, which can't be forced off.
Why do you think the fuse is called watchdog always on fuse and why can you read about WDE locked in the part of the datasheet which you've quoted? |
O-Family
Posted: Fri Aug 19, 2016 1:36 am Post subject: |
If your operation clock is 16MHz, that normally work by my Arduino MEGA250 board.
When Wait was put at the beginning of the program, I didn't normally move, so the whole clearance time of SRAM was doubted.
$Initmicro after the instruction, because the Watchdog is initialized to the minimum of 16ms, it makes no sense to write the ASM code.
Code: |
$regfile = "m2560def.dat"
$crystal = 16000000
$hwstack = 128
$swstack = 128
$framesize = 128
' Waitms 20 'Normal operation.
Waitms 20 'Abnormal movement.
Config Portb.7 = Output
Start Watchdog
Reset Watchdog
Toggle Portb.7
Wait 1
To MWS.
Even your English post, meaning do not know to perform the automatic translation. |
Posted: Fri Aug 19, 2016 2:16 am Post subject: |
O-Family wrote: | Even your English post, meaning do not know to perform the automatic translation. |
What does this mean, do you translate yourself?
You're writing in riddles  |
Posted: Fri Aug 19, 2016 10:33 am Post subject: |
I test this with m2560 with WD FuseBit on.
EDIT: I found funny issue. BOOTRST FuseBit must be disabled while programming. I don`t have time to investigation this
This code work perfectly
Code: | $regfile = "m2560def.dat"
$crystal = 16000000
$hwstack = 64
$swstack = 32
$framesize = 128
Reset Watchdog
Config Portb.7 = Output : Led Alias Portb.7 'Arduino Mega LED
Toggle Led
Wait 1
Reset Watchdog
This code also work...
$crystal = 16000000
$hwstack = 64
$swstack = 32
$framesize = 128
$asm
$end Asm
Reset Watchdog
Toggle Led
Wait 1
Reset Watchdog
End |
..but interesting is that this code don`t work
$crystal = 16000000
$hwstack = 64
$swstack = 32
$framesize = 128
$initmicro
Reset Watchdog
Toggle Led
Wait 1
Reset Watchdog
_init_micro:
$asm
$end Asm
Return |
