AVR Bascom v/s Arduino Programming Software
Karan28
PostPosted: Wed Oct 29, 2014 2:51 pm    Post subject: AVR Bascom v/s Arduino Programming Software Reply with quote
Recently I have began using Arduino hardware. Arduino hardware can be coded by it's own compatible Arduino software. But till now, I was using Bascom comfortably. I want the advice of forum members on whether to switch to compatible Arduino software or continue using Bascom. Will Bascom provide all necessary commands easily? Will it be compatible? Are there any video tutorials to configure Arduino hardware with Bascom? If yes, then do suggest!
Thanks Very Happy
CodeWorm
PostPosted: Wed Oct 29, 2014 3:08 pm    Post subject: Reply with quote
This forum is a BASCOM forum that discusses using ARDUINO HARDWARE, not the software! For using/discussing arduino software you need to join another forum.
arduino and bascom are not compatible. bascom can use the arduino hardware since they have AVR processors. but the software is incompatible.
I would suggest to do a next project(or convert an old one) with arduino and decide what is best for you. It will also differ if you ask on this forum or on arduino forum.
dongags5
PostPosted: Fri Jun 19, 2015 6:22 am    Post subject: Reply with quote
Mark,
I don't understand why you regarded the post by Karan28 as inapropriate as he wrote "Are there any video tutorials to configure Arduino hardware with Bascom?".
Surely this is a worthy topic for this forum as he was wanting to use Bascom software on Arduino hardware. This is exactly what I want to do as Arduino hardware is cheap and as I am perfectly happy with Bascom software it seems to me that it would be an ideal arrangement for some projects.
Any help using Bascom software on an Arduino hardware platform would be most welcome.
Don
PostPosted: Fri Jun 19, 2015 8:35 am    Post subject: Reply with quote
Don : read the whole post and my reply. Do not simply refer to 1 line.
PostPosted: Sat Jun 20, 2015 10:21 am    Post subject: Reply with quote
hello,
I wrote a tutorial with picture for the UNO and the MEGA2560, it has been downloaded more than 100 times, if you have any comments, if you think that it is not clear, I am open to all comments.
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=12472
I add in the next post correlation draws found on the net.
JP
dongags5
PostPosted: Sun Jun 21, 2015 12:22 am    Post subject: Reply with quote
Thanks Duval
I looked at this post a while ago but found no link to "here you will find step by step a protocol to start"
but I can see now that the link has been added and have downloaded the file.
Don
dongags5
PostPosted: Tue Jul 28, 2015 12:25 pm    Post subject: Reply with quote
The Arduino platform appears to rely on set hardware whereas Bascom being just a programming language for AVR processors allows greater flexibility. For instance when very low power is needed and speed is not an important consideration a low frequency clock such as a watch xtal at 32kHz can be used. This allows a much reduced micro power to be obtained. Other components can also be selected for low current consumption. I know a sleep cycle can be used to reduce power but some applications don't allow this.
Whether you use Bascom or Arduino depends greatly on the project requirements and both have their place.
