Code for Gyro reading
Post new topic   Reply to topic    www.mcselec.com Forum Index -> Share your working BASCOM-8051 code here
mastermindjp
PostPosted: Wed Jul 15, 2015 9:40 am    Post subject: Code for Gyro reading Reply with quote
Hello all,
Here is a working code for reading Gyroscope, based on MPU6050, using AT89S52
$crystal = 11059200
$large
Config Scl = P2.2
Config Sda = P2.0
Dim I2ctemp As Integer
Dim Ba As Word
Config Lcdpin = Pin , Db4 = P1.4 , Db5 = P1.5 , Db6 = P1.6 , Db7 = P1.7 , E = P1.3 , Rs = P1.2
Const Mpu6050_wr = &HD0
Const Mpu6050_rd = &HD1
Dim T As Single , X As Word , S As Word , Count As Word , Clock As Word , T1 As Single
Main:
X = 0
S = 0
Clock = 0
T = 0
Waitms 200
Call Write_i2c
If I2ctemp < 100 Then X = X + 1
If I2ctemp > 110 And I2ctemp < 245 Then S = S + 1
Waitms 10
Clock = X + S
T = 500 / Clock
Cls
Lcd "SPEED = " ; T
Lowerline
Lcd "VALUE = " ; I2ctemp
Waitms 50
If T >= 100 Then P0.0 = 0
If T <= 99 Then P0.0 = 1
Waitms 200
Goto Main
Sub Write_i2c
I2cstart
I2cwbyte Mpu6050_wr
I2cwbyte &H6B
I2cwbyte 09
I2cstart
I2cwbyte Mpu6050_wr
I2cwbyte &H1B
I2cwbyte 3
I2cstart
I2cwbyte Mpu6050_wr
I2cwbyte &H19
I2cwbyte 0
I2cstart
I2cwbyte Mpu6050_wr
I2cwbyte &H47
I2cstop
Call Read_i2c
Waitms 10
End Sub
Sub Read_i2c
I2cstart
I2cwbyte Mpu6050_rd
I2crbyte I2ctemp , Nack
I2cstop
Waitms 10
Cls
Lowerline
Lcd "VALUE= " ; I2ctemp
End Sub
also, if code can be improved then kindly let me know...
thanks
regards
PostPosted: Wed Jul 15, 2015 11:55 am    Post subject: Reply with quote
thank you for sharing. i would write goto main as a do..loop.
$crystal = 11059200
$large
Config Scl = P2.2
Config Sda = P2.0
Dim Ba As Word
   X = 0
   S = 0
   Clock = 0
   T = 0
   Waitms 200
   Call Write_i2c
   Waitms 10
   Clock = X + S
   T = 500 / Clock
   Cls
   Lcd "SPEED = " ; T
   Lowerline
   Waitms 50
   Waitms 200
Sub Write_i2c
   I2cstart
   I2cwbyte Mpu6050_wr
   I2cwbyte &H6B
   I2cwbyte 09
   I2cstart
   I2cwbyte Mpu6050_wr
   I2cwbyte &H1B
   I2cwbyte 3
   I2cstart
   I2cwbyte Mpu6050_wr
   I2cwbyte &H19
   I2cwbyte 0
   I2cstart
   I2cwbyte Mpu6050_wr
   I2cwbyte &H47
   I2cstop
   Call Read_i2c
   Waitms 10
End Sub
Sub Read_i2c
   I2cstart
   I2cwbyte Mpu6050_rd
   I2cstop
   Waitms 10
   Cls
   Lowerline
End Sub
mastermindjp
PostPosted: Wed Jul 15, 2015 1:44 pm    Post subject: Reply with quote
Hello Mark,
Thank you.
Will keep that in mind for future projects...
Thanks Very Happy
Regards
Aniruddha
TechiMechi
Debu
PostPosted: Tue Sep 05, 2017 6:19 pm    Post subject: Reply with quote
Hallo all
I am trying this code on Xmega32A4u but I can't.
I use GY-88 module consist MPU6050 HMC5883L BMP085.
The HMC5883L and BMP085 work fine but the MPU6050 don't.
I was try separate code for HMC5883L and BMP085 they are working.
But this code doesn't work.
It is hang on <Print #1 , "Write_i2c :">
Can anybody help me ???? Please
(Sorry for my bad English)
$regfile = "Xm32A4def.dat"
$crystal = 32000000
$hwstack = 84
$swstack = 80
$framesize = 80
$lib "xmega.lib"
$lib"i2c_twi.lbx"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
Config Sysclock = 32mhz
Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1  'Internal 32MHz, no prescaler
Config Submode = New
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled       ' the RTC uses LO priority interrupts
Config Lcdpin = Pin , Db4 = Porta.4 , Db5 = Porta.5 , Db6 = Porta.6 , Db7 = Porta.7 , E = Porta.2 , Rs = Porta.0
Config Lcd = 20x4 , Chipset = Dogm162v3
Cursor Off, NoBlink
Cls
Config Input1 = Cr , Echo = Crlf                           ' CR is used for input, we echo back CR and LF
Open "COM1:" For Binary As #1
Cls
Dim Twi_start As Byte 'This Variable is used by the I2C functions
Open "twic" For Binary As #2
Config Twic = 100000 ' set the I2C bus to 'fast' speed
I2cinit #2
Declare Sub Write_i2c
Declare Sub Read_i2c
Dim Ba As Word
Dim T As Single , X1 As Word , S As Word , Count As Word , Clock As Word , T1 As Single
'*****[ Start of main loop ]****************************************************
  Print #1 , "Main loop "
   X1 = 0
   S = 0
   Clock = 0
   T = 0
   Waitms 200
   Call Write_i2c
   If I2ctemp < 100 Then X1 = X1 + 1
   Waitms 10
   Clock = X1 + S
   T = 500 / Clock
   Cls
   Lcd "SPEED = " ; T
   Lowerline
   Waitms 50
   'If T >= 100 Then P0.0 = 0
   'If T <= 99 Then P0.0 = 1
   Waitms 200
Sub Write_i2c
   I2cstart
   I2cwbyte Mpu6050_wr
   I2cwbyte &H6B
   I2cwbyte 09
   I2cstart
   I2cwbyte Mpu6050_wr
   I2cwbyte &H1B
   I2cwbyte 3
   I2cstart
   I2cwbyte Mpu6050_wr
   I2cwbyte &H19
   I2cwbyte 0
   I2cstart
   I2cwbyte Mpu6050_wr
   I2cwbyte &H47
   I2cstop
   Print #1 , "Call Read_i2c :"
   Call Read_i2c
   Waitms 10
End Sub
Sub Read_i2c
Print #1 , "Read_i2c:"
   I2cstart
   I2cwbyte Mpu6050_rd
   I2cstop
   Waitms 10
   Cls
   Lowerline
End Sub
Shocked Sad
View user's profile AIM Address Yahoo Messenger MSN Messenger
Post new topic   Reply to topic    www.mcselec.com Forum Index -> Share your working BASCOM-8051 code here All times are GMT + 1 Hour
