[solved] Best BASCOM way to handle these many IFs
Sebastian.Heyn
PostPosted: Tue Apr 07, 2015 2:09 pm    Post subject: [solved] Best BASCOM way to handle these many IFs Reply with quote
I am creating a kind of lookup table, but I dont like this below method, so my question is howto do this more elegant?
if byte3=&h00 then f_str=f_str+"bla bla"
if byte3=&h01 then f_str=f_str+"another thing"
problem is that I have many values - and sometimes there are gaps
like 00,01,34,36,8b
I though about putting this to the flash data and use read to read the data, but that would slow down my program significantly.
Any ideas?
PostPosted: Wed Apr 08, 2015 12:05 am    Post subject: Reply with quote
Look at the SELECT CASE statement. This handles that type of construction pretty well. So does LOOKUP into an array in FLASH.
Adrian Jansen
Sebastian.Heyn
PostPosted: Wed Apr 08, 2015 6:58 am    Post subject: Reply with quote
mmhh... thanks i will check out both.
Sebastian.Heyn
PostPosted: Wed Apr 08, 2015 7:34 am    Post subject: Reply with quote
OK.. following test:
48 IF byte3=..... then .... instructions vs. 48 Case...
The byte3 value was simulated in the middle (20ish somewhere) of all the options
If then : 484 cycles -> checks all ifs, even if the value was found
Case: 270 cycles -> stops after the value was found
Each "if" takes 7 cycles
each "else" takes 5 cycles
I guess CASE is the clear favourite in this situation.
lookupstr is a nice function, the code looks much cleaner.
However I need speed so it is not the way to go for me.
I will keep this function in mind in case I need 2-way translation
f_str=lookupstr(0,t_data)   '133 cycles
print f_str
f_str=lookupstr(1,t_data) '137 cycles
print f_str
f_str=lookupstr(2,t_data) '228 cycles
print f_str
f_str=lookupstr(25,t_data) '689 cycles
print f_str
t_data:
data "Hello","","this","","","","","","",""
data "","","","","","","","","",""
data "","","","","","26","","","",""
cored
PostPosted: Wed Apr 08, 2015 8:49 am    Post subject: Reply with quote
If you have a huge amount of strings, some kind of indexing would help http://en.wikipedia.org/wiki/Database_index
PostPosted: Wed Apr 08, 2015 9:00 am    Post subject: Reply with quote
you do know that there is the elseif statement right?
dim bb as Byte
bb=2
if bb=1 then
print "1"
elseif bb=2 then
print "2"
elseif bb=3 then
print "3"
elseif bb=4 then
print "4"
end if
it will evaluate till the condition is true, then it will continue after the end if.
from the database like suggested you could do this : make a crc32 of each string and store that. possible combined with an index
PostPosted: Wed Apr 08, 2015 7:48 pm    Post subject: Reply with quote
If You have code where in multiple places must be printed the same thing/string then You can choose constans.
This constans can be stored in one place in code and qiuck translated to another language for example.
You can multiple times use them in code and compiler store only address of them Smile I think so Very Happy
Const Sign = ">"
Const Str_1 = "String example 1"
Const Str_2 = "String exapmle 2"
Const Error1 = "Error 1WIRE"
Const Error2 = "Error I2C"
   Lcd Error1
   Lcd Error1  'can be used many times
   Lcd Str_2
 String_s = Str_1
I hope every idea can be helpfull Smile
PostPosted: Thu Apr 09, 2015 12:30 am    Post subject: Reply with quote
If the variable you are looking for is a byte, then there are only 256 possible values. So if you had a table indexed by the byte value, the you can go directly to the indexed value without using a search. That is by far the fastest way. Even if your table has gaps, just fill the gap with a null or some other placeholder. If your target result has to be a variable length string, you can still do it with an indexed table, by using two steps. First make a table of words, indexed by the byte value, then make a second table of addresses to the start of each string, indexed by the word value. Then in two steps, you can recover the address of the string, without doing any searching.
Adrian Jansen
PeterM
PostPosted: Thu Apr 09, 2015 10:08 am    Post subject: Reply with quote
There is also ON VALUE you can try
Peter
Sebastian.Heyn
PostPosted: Tue Apr 14, 2015 7:28 am    Post subject: Reply with quote
@AlbertSM:
Actually YES, but I never thought about using it Wink
