interrupt confuse lcd
hamedhamedi
PostPosted: Tue Mar 24, 2015 8:55 am    Post subject: interrupt confuse lcd Reply with quote
Hi
I use lcd nokia3310 with Mr Mirshv code that is in froum,share your code topic.
when i enable the interrupt 5 and 6 on atmega128, the lcd show incorrect position of character ond/or and character.
i have same problem on SED lcd when interrupt occur.
i think when interrupt trigger,after coming back from interrupt service routine, the program flow in data section (that symbol of a font saved)does not come back to the place jumped before interrupt.
i also check the software stack and hardware stack and framesize and set them at a very high value of 128,but problem exist.
what should i do?
Thanks.
Dibor
PostPosted: Tue Mar 24, 2015 11:38 am    Post subject: Reply with quote
Hi.
Disable Interrupts before sending anything to LCD and Enable them after that.
Regards.
View user's profile MSN Messenger
hamedhamedi
PostPosted: Tue Mar 24, 2015 12:09 pm    Post subject: Reply with quote
thanks
interrupt timing is critical.
and also i do not want to lose any interrupt.
any other idea?
Regards
PostPosted: Tue Mar 24, 2015 2:26 pm    Post subject: Reply with quote
there can be 2 reasons (that i can think of): the ISR is not saving registers that are used by the driver. in that case, use the SAVEALL switch.
Or the LCD works with nibbles, and it does not like the time between the 2 nibbles caused by the interrupt. In that case you need to turn off these ints before using the LCD. Or alter the driver so it turns off/on interrupts.
hamedhamedi
PostPosted: Tue Mar 24, 2015 8:15 pm    Post subject: Reply with quote
thank you Albertsm
fine.solved by save all.
