Quick adc to measure the pins xmega
sackoizo
PostPosted: Sat Mar 21, 2015 12:22 pm    Post subject: Quick adc to measure the pins xmega Reply with quote
Welcome! It needs a bit of code to adc in the XMEGA. I measured peak power changes in the order of microseconds + - 1 volt from the norm (5V). Please help.
PostPosted: Sat Mar 21, 2015 2:51 pm    Post subject: Reply with quote
hello,
Did you watch the help: ADC?
You will find a superb example of ADC for mega and atmege and all the necessary information.
Bon courage
JP Wink
sultanm9000
PostPosted: Sat Mar 21, 2015 4:38 pm    Post subject: Reply with quote
'The AUTO feature, will select the highest clockrate possible
'Now give power to the chip
Start Adc
'With STOP ADC, you can remove the power from the chip
'Stop Adc
Dim W As Word , Channel As Byte
'now read A/D value from channel 0
W = Getadc(channel)
Print "Channel " ; Channel ; " value " ; W
Incr Channel
If Channel > 7 Then Channel = 0
Waitms 500
sackoizo
PostPosted: Sat Mar 21, 2015 4:48 pm    Post subject: Reply with quote
For XMEGA does not work the auto. And maybe some code for XMEGA checking how fast the ruler in khz for different frequencies. I checked now at 2MHz pll x31 = 62MHz and looks the same as for the 32MHz. Any suggestions
Edit1
I took the code that checks the samples folder: xm128A1_measure_adc_a_signed_single_ended_mode.bas
sultanm9000
PostPosted: Sat Mar 21, 2015 5:02 pm    Post subject: Reply with quote
Put the work file here
sackoizo
PostPosted: Sat Mar 21, 2015 5:12 pm    Post subject: Reply with quote
$regfile = "xm128a4udef.dat"
$crystal = 62000000                                         '32MHz
$hwstack = 128
$swstack = 128
$framesize = 128
Config Osc = Disabled , 32mhzosc = Enabled , 32khzosc = Enabled       '32MHz
Config Sysclock = 32mhz                                     '32Mhz
'(Dim A As Byte
Out &H50 , &B00000001                                       ' enable  2MHz Oscillator
Out &H55 , &B00011111                                       'PLL Clocksource = 2MHz internal Osc.
'                                                           ,Multiplicator = 16 to get 32 MHz Out
Out &H34 , &HD8                                             'No write protection for 4 cycles
Out &H41 , &B00000000                                       'Prescaler= No division Prescaler A, B and C
While A.0 = 0                                               'Wait for 2MHz Osc. to be ready
   A = Inp(&H51)
Wend
Out &H50 , &B00010001                                       ' enable  PLL
While A.4 = 0                                               'Wait for PLL to be ready
   A = Inp(&H51)
Wend
Out &H34 , &HD8                                             'No write protection for 4 cycles                                         '
Out &H40 , &B00000100                                       'Select PLL as system Clock
Out &H42 , &B00000001                                       'Lock System Clock Settings
'Config Priority = Static , Vector = Application , Lo = Enabled       'config interrupts
'Enable Interrupts
$lib "glcdeadogm128x6.lbx"
Config Graphlcd = 128 * 64eadogm , Cs1 = Portc.4 , A0 = Portc.1 , Si = Portc.5 , Sclk = Portc.7 , Rst = Portc.0
Glcdcmd 141                                                 '&B10001101                                          'pętla zmieniająca kontrast co sekunde
Glcdcmd 32
Waitms 10
Glcdcmd 38
Setfont My6_8                                               'My12_16
Dim Tick As Long
Tick = 0
Dim Ttt As Long
Config Adca = Free , Convmode = Signed , Resolution = 12bit , Dma = Off , Reference = Intvcc , Event_mode = None , Prescaler = 16 , _
Ch0_gain = 1 , Ch0_inp = Single_ended , Mux0 = &B00000000   'Setup Channel 0 in Single Ended Mode
' ADC Clock = 32MHz/512 = 62.5 KHz
Config Tcc0 = Normal , Prescale = 1024
Tcc0_per = 0                                                '31250       '32MHz/1024 = 31250
On Tcc0_ovf Tc0_isr                                         'Setup overflow interrupt of Timer/Counter C0 and name ISR
Enable Tcc0_ovf , Lo                                        'Enable overflow interrupt in LOW Priority
Dim Mensure As Word
Dim Mensurepom As Long
Dim Minn As Word
Minn = 9999
Mensure = 0
Mensurepom = 9999
Dim Tttt As Integer
Dim Measurement As Word
Dim Single_measurment As Single
Dim Single_measurment1 As String * 10
Dim Single_measurment2 As String * 10
Dim I As Byte
For Mensurepom = 0 To 10000
Measurement = Getadc(adca , 0 , &B00000000)
If Measurement < Minn Then Minn = Measurement
Next Mensurepom
Lcdat 1 , 1 , Tick
Lcdat 2 , 1 , Measurement
Tick = 0
Tc0_isr:
'Lcdat 2 , 1 , "tick"
Incr Tick
'Onlyfortesting
$include "font8x8TT.font"
$include "my12_16.font"
$include "my6_8.font"
the code works but how to check how quickly measure adc?
