Byte Variable = Byte Variable return error: source and targe
pinkfloyd11
PostPosted: Fri Mar 13, 2015 10:16 am    Post subject: Byte Variable = Byte Variable return error: source and targe Reply with quote
Hello
I need to set some bits in a byte and after send it.
More precisely I need to set bit 7 of Byte_to_send.
But I give back this:
Error : 242 Line : 90 Data type of source and target variables do not match [ 0] , in File : E:\Dropbox\....Firmware\Test Comandi Singoli\Test Comandi Singoli.bas
What is wrong?
Sub CC1101_Read_Value(ByVal Register_Address as Byte)
       Local Byte_to_send as Byte
       Local Received_Byte as Byte
 'Costruisco il Byte da Inviare secondo la struttura
 '[7] := Header 1
 '[6] := Burst 0
 '[5-0] := Indirizzo Registro
Byte_to_send = Register_Address
 SET Byte_to_Send.7
 SPIout Byte_to_send,1
 SPIin Received_Byte,1
 Print "LETTO = ";  Byte_Ricevuto
 End Sub
Evert :-)
PostPosted: Fri Mar 13, 2015 11:59 am    Post subject: Reply with quote
This compiles fine with 2078.
Give me a complete not working sample. With only the SUB it's hard to debug.
$regfile = "M88def.dat"
$crystal = 8000000
$baud = 19200
$hwstack = 128
$swstack = 128
$framesize = 128
declare Sub CC1101_Read_Value(ByVal Register_Address as Byte)
Dim A As Byte
Config Spi = Soft , Din =Pinb.0 , Dout =Portb.1 , Ss =Portb.2 , Clock =Portb.3
Spiinit
call CC1101_Read_Value(123)
 '[7] := Header 1
 '[6] := Burst 0
 SET Byte_to_Send.7
End Sub
pinkfloyd11
PostPosted: Fri Mar 13, 2015 12:48 pm    Post subject: Reply with quote
' SPI SEND COMMAND
'Direttive al compilatore
$regfile = "m328pdef.dat"
$hwstack = 32
$swstack = 32
$framesize = 32
$crystal = 16000000
$baud = 57600
$Include "CC1101 REGISTER.inc"
CONFIG SUBMODE = NEW
CONFIG Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 16
SPIINIT
Declare Sub CC1101_Init
Declare Sub CC1101_Read_Value(byval Register As Byte)
Declare Sub CC1101_Write_Value(byval Register As Byte , Byval Value As Byte)
Declare Sub CC1101_Reset
Dim Carattere_ASCII as Byte
PRINT " -- TEST SPI COMMAND MENU --"
PRINT "1) READ CONFIG REGISTER"
PRINT "2) READ STATUS REGISTER"
PRINT ""
PRINT ""
DO
Carattere_ASCII = Inkey() 'get ascii value from serial port
If Carattere_ASCII > 0 Then
Print "ASCII = " ; Carattere_ASCII
SELECT CASE Carattere_ASCII
CASE 49
PRINT "READ CONFIG REGISTER"
CC1101_Read_Value(&H0030)
CASE 50
PRINT "READ STATUS REGISTER"
CASE 51
CASE 52
END SELECT
LOOP
'_______________________________________________________________________________________
Sub CC1101_Init()
End Sub
Local Byte_to_Send as Byte
Local Byte_Received as Byte
Byte_to_Send = 0
Byte_Received = 0
'[7] := Header 1
'[6] := Burst 0
Byte_to_Send = Register_Address
SET Byte_to_Send .7
SPIout Byte_to_Send , 1
SPIin Byte_Received , 1
Print "BYTE READ = "; Byte_Received
End Sub
Sub CC1101_Write_Value(Register , Value )
End Sub
Sub CC1101_Reset
End Sub
PostPosted: Fri Mar 13, 2015 1:55 pm    Post subject: Reply with quote
you have :
and then check the implementation, it differs !
when using submode=new, you do not need the DECLARE , just put the sub/function before you call it, for example using an include file.
when you do use declare sub, make sure the declare matches the implementation.
