DMA on ATXmega384C3 at 2.0.7.8.001
Duesentrieb72
PostPosted: Fri Feb 27, 2015 10:19 am    Post subject: DMA on ATXmega384C3 at 2.0.7.8.001 Reply with quote
Hello
I use DMA to receive 6Byte over USARTD0 on ATXmega384C3
With compiler version 2.0.7.7 this works well:
Config Dmach0 = Enabled , Burstlen = 1 , Chanrpt = Disabled , Tci = Hi , Eil = Lo , Singleshot = Enabled , _
Sar = Burst , Sam = Fixed , Dar = Transaction , Dam = Inc , Trigger = &H6B , Btc = 6 , Repeat = 0 , Sadr = Varptr(usartd0_data) , Dadr = Varptr(fmcu_rx_buffer(1))
With new version 2.0.7.8 it doesn't work proper.
I receive 6Byte, first 2Byte are ok, but the last 4Byte are allways Zero
After long try and error I changed Trigger = &H6B to Trigger = Usartd0 and everything works like before.
Does anyone has an idear for this?
Thanks a lot,
Duesentrieb72
[b][color=red](BASCOM-AVR version : 2.0.7.8 )[/b][/color]
PostPosted: Fri Feb 27, 2015 4:11 pm    Post subject: Reply with quote
that is really odd. because : when you use usartd0, &H6B will be used. And when you use a numeric value, the numeric value will be used. &H6B in this case.
I will check it to see if it really differs.
PostPosted: Fri Feb 27, 2015 4:40 pm    Post subject: Reply with quote
I checked. Maybe you changed more? Because in both cases, i get the same binary file.
Duesentrieb72
PostPosted: Fri Feb 27, 2015 4:50 pm    Post subject: Reply with quote
Hi Mark
Configuration für Bascom Compiler 2.0.7.7
Configuration für Bascom Compiler 2.0.7.8
Config Dmach0 = Enabled , Burstlen = 1 , Chanrpt = Disabled , Ctr = Enabled , Singleshot = Enabled , Tci = Hi , Eil = Off , _
Sar = Burst , Sam = Fixed , Dar = Transaction , Dam = Inc , Trigger = Usartd0 , Btc = 6 , Repeat = 0 , Sadr = Varptr(usartd0_data) , Dadr = Varptr(fmcu_rx_buffer(1))
The rest of code is exact the same...
PostPosted: Fri Feb 27, 2015 9:57 pm    Post subject: Reply with quote
I had a look at 2077 vs 2078 but it creates the same code. Please make a small but complete sample that can be tested for 2077 that works, but does not work in 2078.
The dat file has changed in 2078 but it fixed the last entry of the interrupt table. It is not related to DMA.
In your sample i see that EIL=Lo but also OFF.
Duesentrieb72
PostPosted: Mon Mar 02, 2015 10:15 am    Post subject: Reply with quote
Yes, I tried a lot and I left this. I changed to "Lo" and it runs too.
Now, there comes a miracle...
I even changed just for fun back to complete old configuration and it runs too d'oh!
I'm sorry. I can't tell you, what happend.
I really changed to new compiler version only and it doesn't run.
I only changed in DAM configation, because I could see on scope correct UART signals.
I changed from "Trigger = &H6B" to "Trigger = Usartd0" and it run.
Now, I changed back and it runs too
So thanks for your kindly support,
Duesentrieb72
