Multi-functional shield on Arduino Uno
bzijlstra
Bascom Ambassador
PostPosted: Wed Feb 18, 2015 5:01 pm    Post subject: Multi-functional shield on Arduino Uno Reply with quote
This is the hardware:
And here the software to drive the board:
First a atmega328p_pins.inc to translate most of the Arduino pins to Bascom-pins
'Arduino_uno_pins.inc
D0 Alias Portd.0
D1 Alias Portd.1
D2 Alias Portd.2
D3 Alias Portd.3
D4 Alias Portd.4
D5 Alias Portd.5
D6 Alias Portd.6
D7 Alias Portd.7
D8 Alias Portb.0
D9 Alias Portb.1
D10 Alias Portb.2
D11 Alias Portb.3
D12 Alias Portb.4
D13 Alias Portb.5
D14 Alias Portc.0
D15 Alias Pinc.1
D16 Alias Pinc.2
D17 Alias Pinc.3
D18 Alias Portc.4
D19 Alias Portc.5
And here the main program with several tests of the hardware
'Arduino Uno -  Multi-functional board
$regfile "m328pdef.dat"
$crystal = 16000000
$hwstack = 64
$swstack = 64
$framesize = 64
Dim X As Word
Const _shift_delay = 20                                     'shift out delay in microseconds
'beeper = d3 = portd.3 - 0=active
'led1 = d13 = portb.5
'led2 = d12 = portb.4
'led3 = d11 = portb.3
'led4 = d10 = portb.2
'S1 = D15 = pinc.1
'S2 = D16 = pinc.2
'S3 = D17 = pinc.3
$include "arduino_uno_pins.inc"
Config D3 = Output                                          'beeper
Config D13 = Output                                         'led1
Config D12 = Output                                         'led2
Config D11 = Output                                         'led3
Config D10 = Output                                         'led4
Config D15 = Input                                          'switch1
Config D16 = Input                                          'switch2
Config D17 = Input                                          'switch3
Data_out Alias Portb.0                                      ' SER - first 595 pin 14
Latch_out Alias Portd.4                                     ' RCLK- all chips pin 12
Clock_out Alias Portd.7                                     ' SRCLK- all chips pin 11
                                                            'Chip 1 QH' -> 2nd SER
                                                            'OE connected to ground
Config Clock_out = Output                                   'set output to 595.
Config Data_out = Output                                    'set output to 595.
Config Latch_out = Output                                   'set output to 595.
Set Clock_out                                               'switch off 595
Reset Data_out                                              'switch off 595
Reset Latch_out                                             'switch off 595
Dim Pattern As Word
D3 = 1                                                      ' beeper off
Declare Sub Send595(byval Pattern As Word)
'clear display
'              SSSSSSSS      DDDD
'              .GFEDCBA      1234
   Pattern = &B11111111_0000_0000                           'segments active low, display active high
   Call Send595(pattern)
' beeper on/off
D3 = 0                                                      'beeper
Wait 1
D3 = 1
Wait 1
' leds running
For X = 1 To 20
   D13 = 0
   Waitms 100
   D13 = 1
   D12 = 0
   Waitms 100
   D12 = 1
   D11 = 0
   Waitms 100
   D11 = 1
   D10 = 0
   Waitms 100
   D10 = 1
   Waitms 100
Next X
'beep for switch press
D3 = 0                                                      'beeper
Wait 1
D3 = 1
Wait 1
' switches
For X = 1 To 6500
If D15 = 0 Then D13 = 0                                     'S1 - Led1
If D16 = 0 Then D12 = 0                                     'S2 - Led2
If D17 = 0 Then D11 = 0                                     'S3 - Led3
Waitms 1
Next X
D3 = 0                                                      'beeper
Wait 1
D3 = 1
'leds off
D13 = 1
D12 = 1
D11 = 1
D10 = 1
'display, show 1234 - found in www.mcselec.com - work of Ian Dobson
'segment and display
'              SSSSSSSS      DDDD
'              .GFEDCBA      1234
   Pattern = &B11111001_0000_0001                              '1
   Waitms 5
   Pattern = &B10100100_0000_0010                              '2
   Waitms 5
   Pattern = &B10110000_0000_0100                              '3
   Waitms 5
   Pattern = &B10011001_0000_1000                              '4
   Waitms 5
   Shiftout Data_out , Clock_out , Pattern , 0 , 16 , _shift_delay       'send pattern
   Set Latch_out                                             'latch shift reg to outputs
   NOP                                                       'wait abit
   Reset Latch_out                                           'latch off, data written
End Sub
Parts are found in the www.mcselec.com forum.
Have fun
Ben Zijlstra
PostPosted: Wed Feb 18, 2015 5:42 pm    Post subject: Reply with quote
hello !
it's a good idea to make an alias for the pins !
I love and Hate Arduino.
Love, because the shields are an easy way to try , to test, most are cheap and clever.
hate, because Arduino don't speak about port as AVR and Bascom speak.
Where did you find the shield ?
Thanks you
JP
bzijlstra
Bascom Ambassador
PostPosted: Wed Feb 18, 2015 6:18 pm    Post subject: Source Arduino Uno shield Reply with quote
On the board a CE stamp so I think it is from Chinese Electronics Very Happy
7,11 euro. Sounds like Ben Good..
Have fun
Ben Zijlstra
PostPosted: Thu Feb 19, 2015 9:58 pm    Post subject: Reply with quote
Thanks for sharing Ben. Very Happy
Indeed a good idea to create an inc file.
bzijlstra
Bascom Ambassador
PostPosted: Tue Mar 24, 2015 4:24 pm    Post subject: small note on multifunctional board. Reply with quote
One little note on the multifunctional shield.
The display can make a shortcut with the USB connector. In that case segment B of all displays are on.
A piece of tape on the USB connector can prefent this.
Have fun
Ben Zijlstra
