getRC lib OK?
Flyby123
PostPosted: Sun Feb 08, 2015 3:18 pm    Post subject: getRC lib OK? Reply with quote
Hi All,
I seem to have some issues with getRC and Bascom AVR.
Setup:
Bascom AVR 2.0.7.8
Board 1: Arduino Uno board (M328P)
Board 2: Chip45 Crumb Xmega128A3 board
RC network with 10K and 100n ceramic Cap, build as decribed in Bascom help file (getRC command).
Issue:
The Arduino board gives me a value via the comms terminal but it is always 1, even if I change capacitor value (up to 1u) or change resistor value (up to 100K).
Always the value 1, however it does generate a pulse (see scope screenshot).
FYI disconnecting the scope probe sees no difference (so no probe capacitive loading issue there).
For Xmega the value is always 0, and no pulse comes out of the pin, code slighly different.
Tried different ports and pins, result the same.
Lib Faulty?
Test code for Arduino board
 $regfile = "m328pdef.dat"                                ' used micro
   $crystal = 16000000                                      ' used xtal
   $baud = 19200                                            ' baud rate we want
   $hwstack = 40
   $swstack = 40
   $framesize = 40
   config clockdiv = 1                                      ' either use this or change the divider fuse byte
    dim w as word , b as byte
    dim s as string * 6 , ar(6) as byte
    dim RCVal as word
    config portb = output                                   ' make portb an output
     waitms 1000                                            ' wait 1 sec
      toggle portb                                          ' toggle level
      RCval = getrc(PIND , 7)
      print "RC value: " ; RCval                            ' test serial com
      w = w + 1 : s = str(w)                                    ' convert w to a string
      str2digits s , ar(1)                                      ' convert string into an array with binary numbers
    end
TIA
PostPosted: Thu Feb 12, 2015 8:14 pm    Post subject: Reply with quote
I think your clock is to high, try it with an lower speed clock.
Clockdivision = 4
