Bascom does not recognise "BYREF" when declaring a
georgecharlton
PostPosted: Tue Feb 03, 2015 9:05 am    Post subject: Bascom does not recognise "BYREF" when declaring a Reply with quote
I am running Bascom ver. 2.0.7.7 and when I enter a subroutine declaration
eg. DECLARE SUB MYSUB (byref a as byte, BYVAL b as byte)
the compiler/editor does not recognise the word “byref” ( it should change the lettering blue, same as BYVAL
When I attempt to compile it, the error message:
Error: 248 Line: 123 BYVAL should be used in declaration [[112]], in File: C:\dir\file.bas
If I leave “byref” out, it should default to BYREF according to the Declare explanation, but I get the same error message.
any help gratefully accepted.
George C
N.Z.
(BASCOM-AVR version : 2.0.7.7 , Latest : 2.0.7.8 )
PostPosted: Tue Feb 03, 2015 9:44 am    Post subject: Reply with quote
yes I see there is no coloring, will add that.
you should post some small but complete code. i guess what you do is passing a number to a variable declared with byref.
PostPosted: Tue Feb 03, 2015 10:02 am    Post subject: Re: Bascom does not recognise "BYREF" when declari Reply with quote
ByRef gets recognized, and the missing highlight is old news.
Because you call the sub with parameter a as constant, then the call "by reference" is not possible.
ByRef means the address of the original variable is forwarded, if you use a constant, there is no address to forward.
Thus ByVal is required, which creates a temporary variable, where the constant is assigned to.
georgecharlton
PostPosted: Wed Feb 04, 2015 10:31 am    Post subject: Reply with quote
I was using a previously dim'd variable, now it is all working OK without the BYREF.
Thanks for the prompt answers.
George C
PostPosted: Wed Feb 04, 2015 3:45 pm    Post subject: Reply with quote
Then it would have worked.
As you ignored the wish to provide compilable code, so I did in this case:
$Regfile = "m328def.dat"
$crystal = 16000000
$hwstack = 40
$swstack = 16
$framesize = 32
$baud = 57600
Dim gvar As Byte
DECLARE SUB MYSUB(byref a as byte , BYVAL b as byte)
   MYSUB gvar , 1
   Print a ; " " ; b
End Sub
This code compiles without problems in 2.0.7.8, which would be not the case, if ByRef
would have been the culprit.
The culprit was, as so often, sitting in front of the screen.
georgecharlton
PostPosted: Sat Feb 07, 2015 10:57 pm    Post subject: Bascom does not recognise BYREF Reply with quote
albertsm & MWS,
I had corrected the fault and overwritten the problem.
When I tried to re-create the code, I couldn't duplicate the original problem.
However . . .
It has just re-occured in my latest program and was, as you pointed out, due to the sub variable being passed as a constant in the calling line.
By assigning the constant to a variable & using the variable in the sub calling line the compiler is happy.
eg.
declare sub mysub(byref v1 as byte)
mysub $55 '<error!
Compiler flags error, but
x=$55
mysub x '< OK
=compiler happy
Thanks for your assistance
George
