How to Memcopy Multi Index Arrays?
TSEYFARTH
PostPosted: Thu Jan 29, 2015 6:59 am    Post subject: How to Memcopy Multi Index Arrays? Reply with quote
Hello all,
I am just trying the new multi index arrays. This is the code used without the multi index array:
Dim RxBuffer(64) As Byte
   'bts = MEMCOPY(source, target , bytes[ , option])
   bts = MEMCOPY(RxTempBuf(1), Rxbuffer(Idx),Dta_len)   '01/28/15a
Can anyone tell me how to port that to use this new multi index array?
Dim RxBuffer(10,64) As Byte
Thank you,
Tim
AdrianJ
PostPosted: Thu Jan 29, 2015 11:18 pm    Post subject: Reply with quote
So you are trying to copy a 1 dimensional array into one dimension of a multi-dimensional array. I know of no language which allows that as a direct operation.
But of course you can do it easily in a loop:
for bt = 1 to Dta_len
RxBuffer(1,bt) = rxTempBuf(bt)
next
will put the temp buffer in column 1 of the multi-array
Yes of course it will take a bit longer than using memcopy ( although not much, since you are only copying bytes ). If you want it quicker, do it in ASM.
Adrian Jansen
TSEYFARTH
PostPosted: Fri Jan 30, 2015 3:26 am    Post subject: Reply with quote
Hi Adrian,
I thought there might be a way to do it... but without regard to that, the looping does not work. I get an error 61.
   Dim RxTempBuf(64) As Byte
   Dim b_temp1 as byte
   Local Dta_len As Byte
    For b_temp1 = 1 to Dta_len
         Rxbuffer(1,b_temp1) = RxTempBuf(b_temp1)              <===== ERROR 61 HERE
         Print "Rxbuffer(b_temp1)= ";Rxbuffer(b_temp1)
         Print "RxTempBuf(b_temp1)= ";RxTempBuf(b_temp1)
    Next b_Temp1
Compiler says - Error 61 label not found (_X_RXBUFFER)
Ideas? Sure would like to use these multi indexed arrays...
Tim
AdrianJ
PostPosted: Fri Jan 30, 2015 4:02 am    Post subject: Reply with quote
Try it like this, ie use a single byte temporary variable to hold the result from 1 array to the other
   Dim b_temp1 as byte
  dim bt as byte
         bt = RxTempBuf(b_temp1)
         Rxbuffer(1,b_temp1) = bt
    Next b_Temp1
Adrian Jansen
TSEYFARTH
PostPosted: Fri Jan 30, 2015 4:32 am    Post subject: Reply with quote
Hi Adrian,
I had tried that before, but also again after you suggested to be sure... It does not work.
What I do not understand, is with the statement:
or
How does the compiler *know* that the array to FILL is the second array? It goes to the same rational you used for Memcopy... In my tiny brain (where is homer these days!?) two pointers, or arrays or vars - whatever - need to be there. But what do I know! I am sure that Marc had/has a hard time implementing this - but IT SURE IS COOL!
Thanks again for your effort and feedback on this!
Tim
AdrianJ
PostPosted: Fri Jan 30, 2015 8:50 am    Post subject: Reply with quote
Because you specify index 1 ( the first 'column' in the array ) in the assignment during the loop. ( or the second, if you specify BASE 0 ). That one stays fixed, while the other one is incremented by the loop counter.
I cannot see how they could work in the present form using memcopy, since there you cannot specify which index is fixed, and which is to be incremented.
Pity you cant get it working. I must admit I havent had a chance to play with multi-dim arrays yet in Bascom, so I dont really know if they work, but Mark assures us that they do for most simple assignments like here.
Adrian Jansen
i.dobson
PostPosted: Fri Jan 30, 2015 10:52 am    Post subject: Reply with quote
Hi AdrianJ,
Multi multi-dim arrays in Bascom actuualy work quite well. I'm using them to handle the Batterie data from up to 8 Lion batteries (data supplied through SM Bus). You just Need to be careful of afew things:
Don't try to print from an Array element directly (or any complex command for that matter)
Print Array(1,1); won't work
temp=Array(1,1):print temp 'will work
If your using includes make sure that you have atleast one Access to the Array in the main code ( this is enough Var3=Array(Var1,Var1))
I'm actually using alot of the new functions in 7.8 (Multi Array and i2c multi bus). Both of which have saved me alot of work (even though there's a bug in the i2c Multi lib with regards to handling the err bit, see my thread for details).
Regards
Ian Dobson
PostPosted: Fri Jan 30, 2015 11:03 am    Post subject: Reply with quote
yes that is a bug. to workaround, access the multi array in your main code once.
memcopy should or could work but a quick test shown it doesnt. i will have a look at it.
the line in your sample should show : Bts = Memcopy(rxtempbuf(1) , Rxbuffer(1 , 1) , 64) '01/28/15a
because the array has multi dim, you need to provide these dimensions as well.
TSEYFARTH
PostPosted: Fri Jan 30, 2015 6:57 pm    Post subject: Reply with quote
Thanks for the clarification everyone!
Tim
