Return in ISR -- AVR Reset ??
Jogi864
PostPosted: Fri Dec 12, 2014 10:01 pm    Post subject: Return in ISR -- AVR Reset ?? Reply with quote
Hi Bascom Users,
I have a question. I have connect a 12er Keypad on Port A on a Atmel 1284P.
All connections goes over a Resistor 470R on every Line.
Row 1= A1, Row2 = A2.... Col1=A5, Col2= A6...and so on.
i use PCINT to for Interrupt.
Here is the Code what is not working. It seems that the Avr do a Reset when he comes to the "Return" who is in the If.. then.. circle in the ISR (ok sorry for my bad English)
$regfile = "m1284pdef.dat"
$crystal = 14745600
$hwstack = 128
$swstack = 128
$framesize = 128
$baud = 9600
Dim Ma As Byte
Dim Z As Byte
Ddra = &B11110000
Porta = &B00001111
Print "                      ready..."
Enable Pcint0
Pcmsk0 = &B00001111
On Pcint0 Taste
Ma = 1
Open "com1:" For Binary As #1
Incr Z
Print #1 , "Zähler:" ; Z
Print #1 , "Loop"
Print #1 , "Ma: " ; Ma
Wait 3
Taste:
Print #1 , "Jetzt in ISR"
If Ma = 1 Then
     Ma = 2
     Pcifr.0 = 1
Print #1 , "Jetzt ganz in ISR"
Pcifr.0 = 1
Ma = 1
I dont know why this is not working????
but this works:
$crystal = 14745600
$hwstack = 128
$swstack = 128
$framesize = 128
$baud = 9600
Dim Ma As Byte
Dim Z As Byte
Ddra = &B11110000
Porta = &B00001111
Print "                      ready..."
Enable Pcint0
Pcmsk0 = &B00001111
On Pcint0 Taste
Ma = 1
Incr Z
Print #1 , "Loop"
Wait 3
Taste:
Select Case Ma
Case 1:
      Ma = 2
Case 2:
      Ma = 1
End Select
Pcifr.0 = 1
PostPosted: Fri Dec 12, 2014 10:27 pm    Post subject: Reply with quote
Look up the help for "On Interrupt", it will give you the answer.
i.dobson
PostPosted: Sat Dec 13, 2014 9:51 am    Post subject: Reply with quote
Hello,
Simply put you have Return within an if, the Compiler will only use a RETI (Return from Interrupt) for the first return that it sees outside conditions.
So modify your code to use IF,ELSE,ENDIF,RETURN
Regards
Ian Dobson
http://www.planet-ian.com
Visovian
PostPosted: Sat Dec 13, 2014 2:46 pm    Post subject: Reply with quote
I would try:
Taste:
If Ma = 1 Then
     Ma = 2
     Pcifr.0 = 1
     Goto Fin
Pcifr.0 = 1
Ma = 1
Fin:
