3rd TImer
yashrs
PostPosted: Tue Dec 09, 2014 6:38 pm    Post subject: 3rd TImer Reply with quote
From here : http://avrhelp.mcselec.com/index.html?config_timer1.htm
$regfile = "8515def.dat"                                   ' specify the used micro
$crystal = 4000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
$hwstack = 32                                               ' default use 32 for the hardware stack
$swstack = 10                                               ' default use 10 for the SW stack
$framesize = 40                                             ' default use 40 for the frame space
Config Timer1 = Pwm , Pwm = 8 , Compare_A_Pwm = Clear_Up , Compare_B_Pwm = Clear_Down , Prescale = 1
'to set the PWM registers, just assign a value to the compare A and B registers
Compare1a = 100
Compare1b = 200
'Or for better reading :
Pwm1a = 100
Pwm1b = 200
I have connected my two motors to first and second ports. By using Pwm1a and Pwm1b I am able to control the speed of those two motors. How do I control the speed of the third motor ? Please help.
Tiny
PostPosted: Tue Dec 09, 2014 10:55 pm    Post subject: Reply with quote
Dear eaters,
Use timer0 to control the third pwm channel, portb.0 (oc0)
Kind regards, Tiny
