preference of logical operation in bascom avr
hamedhamedi
PostPosted: Fri Dec 05, 2014 6:06 pm    Post subject: preference of logical operation in bascom avr Reply with quote
i want to know wich of operation is claculate in basic first?
and or not?
for example when i write the code:
if a>b and c<d or f>g and g<d then set status_bit
which operation calculate first and which one second?
PostPosted: Fri Dec 05, 2014 6:26 pm    Post subject: Reply with quote
Why not use brackets () to make it clearer for you and the Compiler:-
so do you mean:
if (a>b and c<d) or (f>g and g<d) then set status_bit
or maybe
if a>b and (c<d or f>g) and g<d then set status_bit
use brackets to group the conditions you want to combine
Ian Dobson
hamedhamedi
PostPosted: Fri Dec 05, 2014 7:29 pm    Post subject: Reply with quote
i test brackets (), it dont work on bascom!
PostPosted: Fri Dec 05, 2014 7:41 pm    Post subject: Reply with quote
Oh sorry, I though that worked in Bascom. Looks as if I've spent far to much time programming in other languages in the last few months.
Ian Dobson
hamedhamedi
PostPosted: Fri Dec 05, 2014 8:18 pm    Post subject: Reply with quote
so what can i do?
PostPosted: Fri Dec 05, 2014 8:58 pm    Post subject: Reply with quote
The only Thing I can think of is split the IF into several if's that set a variable, that you later use something like
Result=0
if A > 0 and B > 0 then
  Result=1
endif
if Result=0 and C>0 and D>0 then
 Result=1
endif
if Result = 1 then
 Do something
endif
Not nice, but atleast it's obvious what the code does. Another way would be to use else to handle the or, something like
Result=0
  Result=1
else
if  C>0 and D>0 then
 Result=1
endif
if Result = 1 then
 Do something
endif
Ian Dobson
PostPosted: Fri Dec 05, 2014 9:57 pm    Post subject: Reply with quote
Question was "what is first and what is second"
I always think that is simple but I test this in simulator (run LCD also)
$sim
$regfile = "m32def.dat"
Dim A As Byte , B As Byte , C As Byte , D As Byte , F As Byte , G As Byte
Dim Status_bit As Bit
A = 1
B = 1
C = 1
D = 2
F = 2
G = 1
If A > B And C < D Or F > G And G < D Then Set Status_bit
Lcd Status_bit
Or is tested at the end
This work too
$sim
A = 1
B = 1
C = 1
D = 2
F = 2
G = 1
If A > B Then
 If C < D Then Set Status_bit
Elseif F > G Then
 If G < D Then Set Status_bit
'If A > B And C < D Or F > G And G < D Then Set Status_bit
Lcd Status_bit
With IF`s code is 16 bytes smaller Very Happy I test this (without lcd routines)
16mk
PostPosted: Sat Mar 04, 2023 11:32 am    Post subject: Reply with quote
EDC writes:
$sim
= 1
= 1
= 1
= 2
= 2
= 1
Lcd Status_bit
In my example, it turns out that the conditions are checked in the order in which they were written. Try to check two conditions:
T = 3, K = &H80, N = &HAA
1.    If T > 2 And K <> &H0D Or T > 2 And N <> &HAA Then
2.    If T > 2 And N <> &HAA Or T > 2 And K <> &H0D Then
Mathematically both cases are equivalent: A or B, the second B or A but in Bascom 2085 they give different results 1. false 2. true
Checking one by one comes out as in Bascom, mathematically both true.
Maybe in version 2085 something has changed but the problem is there.
Bascom 2085
