Xmega 128A3U and buffered serialout error
ivangel
PostPosted: Mon Dec 01, 2014 10:52 pm    Post subject: Xmega 128A3U and buffered serialout error Reply with quote
As in the title, after declaring a desire to use Buffered Serialin, getting a mass of errors:
$regfile = "xm128A3Udef.dat"
$crystal = 32000000
$hwstack = 200                                              ' default use 32 for the hardware stack
$swstack = 200                                              'default use 10 for the SW stack
$framesize = 200                                            'default use 40 for the frame space
Config Osc = Enabled , 32mhzosc = Enabled , 32khzosc = Enabled
'configure the systemclock
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled       'Enable Lo Level Interrupts
$lib "xmega.lib"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
Bitwait Osc_status.1 , Set                                  'Check if 32MHz Oscillator is ready
Bitwait Osc_status.2 , Set                                  'Check if internal 32.768 KHz Oscillator is ready
Osc_dfllctrl = 0                                            'The internal 32.768 KHz Oscillator is used for calibration
Dfllrc32m_ctrl.0 = 1                                        'Enable DFLL and autocalibration
'$include "enc28j60.inc"
$lib "tcpip.lbx"
$lib "datetime.lbx"
$lib "mcsbyteint.lbx"
$lib "Mcs.lbx"
Config Com7 = 57600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8       'usarF0
Open "com7:" For Binary As #7
'Usartf0_baudctrla = 1                                       '|=1M          1047|=115.2k
'Usartf0_baudctrlb = 0                                       '|   bscale    164 |
Config Serialout6 = Buffered , Size = 254
Errors:
    Error : 5 Line : 2073 No more space for BIT [_RS_BUFCOUNTW6] , in File : C:\Users\Marcin\Desktop\SEM\WWW do Webserver\Server_1.bas
    Error : 5 Line : 2073 No more space for BIT [_RS_TAIL_PTRW6] , in File : C:\Users\Marcin\Desktop\SEM\WWW do Webserver\Server_1.bas
    Error : 238 Line : 2073 Variable is not dimensioned as an array [_RS232OUTBUF6(1)] , in File : C:\Users\Marcin\Desktop\SEM\WWW do Webserver\Server_1.bas
    Error : 263 Line : 2073 Array index out of range [1] , in File : C:\Users\Marcin\Desktop\SEM\WWW do Webserver\Server_1.bas
    Error : 104 Line : 2073 LoadReg error [_RS232OUTBUF6(1)] , in File : C:\Users\Marcin\Desktop\SEM\WWW do Webserver\Server_1.bas
    Error : 222 Line : 2073 Illegal character [expected (, got '' [_RTSCTS7]] , in File : C:\Users\Marcin\Desktop\SEM\WWW do Webserver\Server_1.bas
    Error : 320 Line : 2073 [syntax error, token = '{'] , in File : C:\Users\Marcin\Desktop\SEM\WWW do Webserver\Server_1.bas
    Error : 222 Line : 2073 Illegal character [expected (, got '' [_RS232_BUFSIZE_OUT6]] , in File : C:\Users\Marcin\Desktop\SEM\WWW do Webserver\Server_1.bas
    Error : 61 Line : 2073 Label not found [_SENDCHAR7 ] , in File : C:\Users\Marcin\Desktop\SEM\WWW do Webserver\Server_1.bas
Am I doing something wrong?
www.midaz.com.pl
PostPosted: Tue Dec 02, 2014 8:39 pm    Post subject: Reply with quote
no it is a known problem. when you write to support you can get a fix.
