Higher index value for LOOKUPSTR
ivangel
PostPosted: Sun Nov 30, 2014 1:40 pm    Post subject: Higher index value for LOOKUPSTR Reply with quote
As the topic, it is possible
increase the value index for LOOKUPSTR? I understand that the length of the variable "string" can be up to 254 Byte. "Date" is the perfect place to store, for example: HTML code, but 255 of the code elements very limited. Regards
www.midaz.com.pl
PostPosted: Sun Nov 30, 2014 2:00 pm    Post subject: Reply with quote
Have a look at $BIGSTRINGS
ivangel
PostPosted: Sun Nov 30, 2014 2:18 pm    Post subject: Higher index value for LOOKUPSTR Reply with quote
Thank you for your answer, but I do not think it would solve the problem. I is not about to give an string element "table" DATA could be longer than 254 Byte, what is it for $BIGSTRINGS, but I can these elements using LOOKUPSTR read more than 255.
From Bacom Help:
Syntax
var = LOOKUPSTR( value, label )
The index value can have a maximum value of 255.
www.midaz.com.pl
PostPosted: Sun Nov 30, 2014 10:27 pm    Post subject: Reply with quote
In 2077, you can already use a word for the index. So 256 should work.
ivangel
PostPosted: Mon Dec 01, 2014 10:40 pm    Post subject: Higher index value for LOOKUPSTR Reply with quote
Ok, i try.
www.midaz.com.pl
