Arduino Nano and TSC230 color sensor
Bascom Ambassador
PostPosted: Fri Sep 05, 2014 10:43 am    Post subject: Arduino Nano and TSC230 color sensor Reply with quote
TSC230 - Color Sensor
Single-supply operation 2.7 to 5.5 volt
High-resolution conversion of light intensity to frequency
Programmable color and full-scale output frequency
Output frequency: 5 volt
Duty cycle: 50%
Distance to object: max 10 mm
Value of RGB between 1200 and 3500, with this Bascom-AVR program.
S0 and S1: Output frequency scaling selection inputs
S2 and S3: photodiode type selection inputs
Out: Output frequency
OE pin: Output frequency enable pin (active low)
TSC230 has four photodiode types. Red, Blue, Green and Clear.
We can choose the different type of photodiode by different combinations of S2 and S3.
Connection to the Arduino Nano:
S0 = D6 = Portd.6
S1 = D5 = Portd.5
S2 = D4 = Portd.4
S3 = D3 = Portd.3
Out = D2 = Portd.2 = INT0
OE connect to GND
VCC to 5 volt
GND to GND
During 100 mSec the frequency is measured of Red, Green and Blue. This is done by counting the interrupts on INT0 which is connected to the OUT of the TSC230. The value is send to the serial port.
This is done in a do loop cycle for all three colors RGB.
Picture of Arduino Nano and TSC230 module
With a scope checking the frequency of OUT
Terminal output with RGB values
'Arduino Nano with TSC230 color sensor
$regfile "m328pdef.dat"
$baud = 9600
$hwstack = 48
$swstack = 48
$framesize = 48
$loadersize = &H800
S0 Alias Portd.6
S1 Alias Portd.5
S2 Alias Portd.4
S3 Alias Portd.3
S_out Alias Portd.2
Config S0 = Output
Config S1 = Output
Config S2 = Output
Config S3 = Output
Config S_out = Input
Dim Count As Word
Dim Count_r As Word
Dim Count_g As Word
Dim Count_b As Word
Set S1
Set S0
Reset S2
Reset S3
Config Int0 = Falling
On Int0 Myisr
Enable Int0
   Count_r = Count
   Print "Red = " ; Count_r
   Set S2
   Set S3
   Count = 0
   Waitms 100
   Count_g = Count
   Print "Green = " ; Count_g
   Reset S2
   Set S3
   Count = 0
   Waitms 100
   Count_b = Count
   Print "Blue = " ; Count_b
   Reset S2
   Reset S3
   Count = 0
   Waitms 100
   Print Chr(27) ; "[2J"; 'ANSI CLS goto 0/0
Myisr:
Incr Count
Have fun
Ben Zijlstra
PostPosted: Fri Sep 05, 2014 10:53 pm    Post subject: Reply with quote
hi Ben
Thanks for sharing. Nice and simple code. I need to get myself such a sensor too. Always have been intrigued by them. Dont have a practical use for it yet. I do know you and Theo had a great project for such a sensor.
Hope to see that project some day.
