SPI communication with MCP3008
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051
muc82
PostPosted: Mon May 12, 2014 6:56 pm    Post subject: SPI communication with MCP3008 Reply with quote
I have an problem with communication over SPI. I would like to read an channel from MCP3008 10-bit AD converter. I always get maximum value readout in the controller, also if the MCP is not connected. Has someone experience with communicating over the SPI? Please for help.
My program bellow:
Dim A1 As Byte , C(2) As Byte
Dim B2 As Word , B3 As Word , B4 As Word , B44 As Word
Dim Cs As Bit
Config Lcdpin = Pin , Db4 = P1.0 , Db5 = P1.1 , Db6 = P1.2 , Db7 = P1.3 , E = P1.4 , Rs = P1.5
Config Spi = Soft , Din = P3.2 , Dout = P3.3 , Cs = P3.4 , Clk = P3.5 , Data Order = Msb , Nocs =
Spiinit
Config Lcd = 20 * 4
Cursor Off Noblink
A1 = &B00011000
Set Cs
Reset Cs
Spiout A1 , 1
Spiin C(1) , 2
Set Cs
Waitms 50
B2 = C(1)
Shift B2 , Left , 2
Shift C(2) , Right , 6
B3 = C(2)
B4 = B2 + B3
If B4 <> B44 Then
  Locate 1 , 1 : Lcd ; "B4  " ; B4
   B4 = B44
Any suggestions what is wrong in the program to get readout from the MCP?
Thank you.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051 All times are GMT + 1 Hour
