No response from meg640
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
nisse
PostPosted: Wed Apr 09, 2014 9:53 pm    Post subject: No response from meg640 Reply with quote
Hi
I have a meg640 that has been working fine untill just now.
I was programming it from Bascom with a USB-ISP programmer when downloading suddenly slowed down. It finished, but in more than double the normal time.
After this the chip doesn't work, I don't even get any response when trying to reprogram it, no chip ID, nothing but unknown chip FFFFF.
The programmer works, tried it with other chips. The meg640 is run from an external clock.
I suspect a fuse bit or two got messed up... Sad
Any ideas on how i can solve this?
PostPosted: Thu Apr 10, 2014 10:03 pm    Post subject: Reply with quote
it is simple to solve : connect a clock signal (for example oscillator output from a working avr circuit) to the xtal input. Look in the pdf to see which pins server as input and output.
then change the fuse bytes to the proper value.
some times pulling the usb cable and plug it again can help too. when you use the jumper to power the circuit you need to take care not to draw too much current from the usb port.
nisse
PostPosted: Fri Apr 11, 2014 6:32 am    Post subject: Reply with quote
Thanks Mark, but its already running from an external oscillator Sad
PostPosted: Fri Apr 11, 2014 8:58 am    Post subject: Reply with quote
but is that external osc still working ?
and does the programmer still work ?
nisse
PostPosted: Fri Apr 11, 2014 10:26 am    Post subject: Reply with quote
yes
yes
Guess I have to get the 0.4mm solder iron out and replace that AVR Sad
Paulvk
PostPosted: Sun Apr 13, 2014 11:42 pm    Post subject: Reply with quote
Hello nisse
Have you tried a 1Mhz clock to the AVR others have noted that this has worked
Regards Paul
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
